Protecting your programming laptop / computer against surges
Hi all, is there anyway to protect the computer I'm using? I use a surface pro 4. I have in the past, while using a 12v power supply had a fault with a board and the current destroy the USB port. I now program through a hub, but still unsure if there's anyway to protect the unit.
Is the only true way to protect from programming issues disconnect everything?
Any advice for a newbie helpful!
You won't destroy your USB port with programming errors but you might do it with wiring errors. Using a USB hub is a good way to protect against such errors but you must ensure you're using a hub with it's own power and power isolation from the host. In my experience not all self-powered hubs fulfill this requirement.
There are USB protection connectors available that actively protect the PC hardware but a good hub is usually the cheaper alternative.
I do agree it was likely a wiring error. My own likely!
I'll look for a USB protection connector, thanks for the advice. Makes sense they would exist but never even thought to look for one.
Thanks mate!
