Hello guys, i have an Arduino Uno board and i plan to make an alarm system for my home heating system , which is based on coal ..
I want to install on it a GSM Shield which will call a number in case the pressure or the temperature in the radiator system is too high , or if the carbon monoxide in the room is in a dangerous quantity.
**I looked for the parts on the DX website , maybe you guys can tell me if one of these GSM modules are ok : **
For the pressure of the water i`m looking at this sensor :
For the water temperature i`m looking at this sensor , will be connected on the outer part of the radioator pipe , and insulated for minimum losses :
https://www.dx.com/p/water-proof-ds18b20-temperature-probe-90cm-142889#.W-gukNIzaUk
For power supply i will use something like this :
A buzzer for local alarm :
Carbon monoxide sensor :
I will find a box to put all of these toghether .
So let`s recapitulate :
Arduino Uno - in stock
Wires for connections - in stock
GSM SHIELD -SIM900 or similar as per options above - to order
Water pressure sensor : 5V G1/4 0-1.2 MPa Pressure Sensor , Output Voltage: 0.5-4.5V DC -to order
Temperature sensor : DS18B20; Voltage: 3.05.5V; Temperature range:-55'C~+125'C - to order
Power supply : AC 100~240V to DC 9V 2A
Buzzer for local alarm - to order
Carbon monoxide sensor : mq-7 or produino-ccs811
Do i need some additional hardware ?
As this is my first project with Arduino ,any advice will be highly appreciated
