Protenta x8 loses IoT cloud connectivity when the LAN is plugged in
I currently have is that Protenta x8 loses connection to the IoT cloud when I plug in the LAN cable.
I plug in the LAN cable so that I can connect the other end of the LAN cable into a PLC and read tags published by the PLC. Read the tags and push them to the cloud dashboard using Node-red locally running on the x8.
Is there a workaround to this problem?
Thank you,
Karthik
