Protocol error in uloading sketch to ender 3 v1.1.4
Using library U8glib-HAL at version 0.5.4 in folder: C:\Users\DIPANKAR\Documents\Arduino\libraries\U8glib-HAL
"C:\Users\DIPANKAR\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\DIPANKAR\AppData\Local\Temp\arduino\sketches\E6A9A3B488AABE891361C6819618CF1D/Marlin.ino.elf"
Sketch uses 118416 bytes (91%) of program storage space. Maximum is 130048 bytes.
Global variables use 7163 bytes (43%) of dynamic memory, leaving 9221 bytes for local variables. Maximum is 16384 bytes.
"C:\Users\DIPANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude" "-CC:\Users\DIPANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf" -v -V -patmega1284p -carduino "-PCOM10" -b115200 -D "-Uflash:w:C:\Users\DIPANKAR\AppData\Local\Temp\arduino\sketches\E6A9A3B488AABE891361C6819618CF1D/Marlin.ino.hex:i"
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\DIPANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
     Using Port                    : COM10
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
     AVR Part                      : ATmega1284P
     Chip Erase delay              : 55000 us
     PAGEL                         : PD7
     BS2                           : PA0
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
       flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 5.0
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading input file "C:\Users\DIPANKAR\AppData\Local\Temp\arduino\sketches\E6A9A3B488AABE891361C6819618CF1D/Marlin.ino.hex"
avrdude: writing flash (118416 bytes):
Writing | ##############################
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x90
I have deleted your other cross-post @dpunkr1111.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
