ciao a tutti!!
vi pongo un problema che sto faticando davvero a risolvere!!
devo configurare con il mio arduino 2009 il sensore di temperatura DS1821, sul sito di arduino ho trovato questo codice di esempio:
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10); // on pin 10
void setup(void) {
// initialize inputs/outputs
// start serial port
void loop(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] != 0x10) {
Serial.print("Device is not a DS18S20 family device.\n");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print("P=");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print( OneWire::crc8( data, 8), HEX);
//Converting HEX to something meaningful (Temperature)
//In order to convert the HEX code to a temperature value, first you need to identify if you are using a DS18S20, or DS18B20 series sensor. The code to read the temperature needs to be slightly different for the DS18B20 (and DS1822), because it returns a 12-bit temperature value (0.0625 deg precision), while the DS18S20 and DS1820 return 9-bit values (0.5 deg precision).
//First off, you need to define some variables, (put right under loop() above)
//int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
//Then for a DS18B20 series you will add the following code below the Serial.println(); above
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
//This block of code converts the temperature to deg C and prints it to the Serial output.
questo codice legge e stampa il valore letto dalla temperatura sulla seriale, io invece avevo bisogno di prendere questo valore come numero reale decimale per infilarlo in un algoritmo.
l'idea era un'altra, io avrei bisogno che mi vega sputato un valore reale del tipo per esempio 32.8 che, memorizzato in una variabile, possa essere inserito in un'altra parte di codice...il fatto che sia diviso in più parti è un handicap! :-[
Be una volta che hai i 2 valori e il segno te li ricostruisci.
Un esempio in C:
#include <string.h>
double valorenum;
char valore[20], str[10];
SerialRead(str); //Legge Whole
strcpy (valore, str); //Copia Whole in valore
strcat (valore,"."); // Concacatena il punto a whole
SerialRead(str) //Legge Fract
strcat (valore, str); //concatena Fract a valore dopo il punto
valorenum = atof(valore); //Trasforma la stringa in un float
Se tu usi altri linguaggi sul PC devi usare una routine diversa, ma il senso e' lo stesso.
P.S.
SerialRead () non e' una funzione standard del C ma la funzione che usi tu per leggere dalla seriale a cui e' collegato Arduino e quindi potrebbe chiamarsi anche diversamente, era solo per farti capire la tecnica.
Ok capito!!a questo punto, sai pensavo, invece di usare "serialRead" (o similari) potrei convertire whole in una stringa, copiarlo in valore, concatenare il punto fare lo stesso barbatrucco per fract e convertire la stringa con atof...comunque l'idea è ottima!!grazie infinite!!
credo tu abbia ragione...il problema è che sto approcciando adesso quindi per adesso brancolo un pò nel buio...devo controllare bene perchè io necessito di temperature precise al decimo quindi dovrei combiare sensore!!
ora guardo!!grazie!! :)...comunque il mio dubbio permane leggermente!!posso usare quel codice oppure devo modificare gli indirizzi?mi sembrano abbastanza simili...magari la struttura di acquisizione è la stessa ma devo rivedere qualcosa..
HIGH-RESOLUTION TEMPERATURE READINGS
The user can calculate temperature values with higher than 8-bit resolution using the data remaining in
the counter and slope accumulator when the temperature conversion is complete.
Pero ha delle limitazioni, non si puo usare nella lettura continua.
E bisogna legere 2 registri e fare delle operazioni matematiche per avere i decimi.
Di quale codice parli ?
Di quello che hai postato all' primo messaggio ?
esatto quello li!!anche se per quello che mi hai detto adesso che bisogna aprire due registri per avere i decimi, già cambia in maniera considerevole purtroppo... :-[
Ok, scusate ma forse con la dicitura 2 registri ho confuso un po le idee.
Il DS ha diverse possibilita di funzionamento. da 9 a 12 bit di precisione.
Dato che lavora con un registro a 8 bit per leggere le temperature si fanno 2 letture separate di 2 byte che contengono ognuno una parte di lettura.
I 2 byte vanno uniti per poter avere la lettura che ci interessa.
