Hello everyone, I am doing a project, and I am using the Protothreads library, however the printing on a 16X2 LCD for the I2C module has not worked for me, when I load it it does not work, however if I load it without the library from Protothreads if it works. I thank the person who can help me
I will attach the 2 codes that I use for the tests.
CODE WHIT ProtoThreads ---- void I2CLED ---- NOT WORKS
#include <pt.h>
#include <Wire.h>
LiquidCrystal_I2C lcd (0x27, 16, 2);
#define DELAYWS 100 // Tiempo de Respuesta WS2812
#define DATOS 33 // Pin Datos WS2812
#define NUMPIXELES 60 // Numero de Pixeles
Adafruit_NeoPixel NEO(NUMPIXELES, DATOS, NEO_GRB + NEO_KHZ800);
int NA = 16;
int NB = 16;
int MQ9= 10;
String T1 =" BIENVENIDOS TUNEL UMNG ";
String T2 ="NIVEL DE CO: " ;
int Inicio, Final = 0;
int Posicion = NA;
const byte S1 = 3;
const byte S2 = 4;
const byte S3 = 5;
const byte S4 = 6;
const byte S5 = 7;
const byte S6 = 8;
const byte S7 = 9;
const byte S8 = 10;
int D1;
int D2;
int D3;
int D4;
int D5;
int D6;
int D7;
int D8;
struct pt PT1;
struct pt PT2;
struct pt PT3;
struct pt PT4;
PT_INIT(&PT1);
PT_INIT(&PT2);
PT_INIT(&PT3);
PT_INIT(&PT4);
FC51(&PT1);
I2CLED(&PT2);
void I2CLED(struct pt * pt){
PT_BEGIN(pt)
static long t = 0;
lcd.backlight();
lcd.init();
do{
MQ9=analogRead(A1);
lcd.setCursor(0,1);
lcd.print(T2);
lcd.print(MQ9);
lcd.setCursor(Posicion,0);
lcd.print(T1.substring(Inicio,Final));
t=millis();
PT_WAIT_UNTIL(pt, ((millis()-t)<200));
lcd.clear();
if (Inicio == 0 && Posicion > 0){
Posicion--;
Final++;
else if(Inicio == Final){
Inicio = Final = 0;
Posicion = NA;
else if(Final == T1.length()&& Posicion == 0){
Inicio++;
else {
Inicio++;
Final++;
}while(true);
PT_END(pt);
void FC51(struct pt * pt){
PT_BEGIN(pt);
pinMode(S1, INPUT);
pinMode(S2, INPUT);
pinMode(S3, INPUT);
pinMode(S4, INPUT);
pinMode(S5, INPUT);
pinMode(S6, INPUT);
pinMode(S7, INPUT);
pinMode(S8, INPUT);
pinMode(DATOS, OUTPUT);
NEO.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
do{
NEO.setBrightness(200); // Brillo WS2812
NEO.show();
//delay (DELAYWS);
NEO.clear();
D1 = digitalRead(S1);
if (D1 == LOW) {
NEO.setPixelColor(0, NEO.Color(0, 255, 255));
NEO.setPixelColor(1, NEO.Color(0, 255, 255));
NEO.setPixelColor(2, NEO.Color(0, 255, 255));
NEO.setPixelColor(3, NEO.Color(0, 255, 255));
NEO.setPixelColor(4, NEO.Color(0, 255, 255));
D2 = digitalRead(S2);
if (D2 == LOW) {
NEO.setPixelColor(5, NEO.Color(0, 255, 255));
NEO.setPixelColor(6, NEO.Color(0, 255, 255));
NEO.setPixelColor(7, NEO.Color(0, 255, 255));
NEO.setPixelColor(8, NEO.Color(0, 255, 255));
NEO.setPixelColor(9, NEO.Color(0, 255, 255));
NEO.setPixelColor(10, NEO.Color(0, 255, 255));
D3 = digitalRead(S3);
if (D3 == LOW) {
NEO.setPixelColor(11, NEO.Color(0, 255, 255));
NEO.setPixelColor(12, NEO.Color(0, 255, 255));
NEO.setPixelColor(13, NEO.Color(0, 255, 255));
NEO.setPixelColor(14, NEO.Color(0, 255, 255));
NEO.setPixelColor(15, NEO.Color(0, 255, 255));
NEO.setPixelColor(16, NEO.Color(0, 255, 255));
D4 = digitalRead(S4);
if (D4 == LOW) {
NEO.setPixelColor(17, NEO.Color(0, 255, 255));
NEO.setPixelColor(18, NEO.Color(0, 255, 255));
NEO.setPixelColor(19, NEO.Color(0, 255, 255));
NEO.setPixelColor(20, NEO.Color(0, 255, 255));
NEO.setPixelColor(21, NEO.Color(0, 255, 255));
NEO.setPixelColor(22, NEO.Color(0, 255, 255));
D5 = digitalRead(S5);
if (D5 == LOW) {
NEO.setPixelColor(23, NEO.Color(0, 255, 255));
NEO.setPixelColor(24, NEO.Color(0, 255, 255));
NEO.setPixelColor(25, NEO.Color(0, 255, 255));
NEO.setPixelColor(26, NEO.Color(0, 255, 255));
NEO.setPixelColor(27, NEO.Color(0, 255, 255));
NEO.setPixelColor(28, NEO.Color(0, 255, 255));
D6 = digitalRead(S6);
if (D6 == LOW) {
NEO.setPixelColor(29, NEO.Color(0, 255, 255));
NEO.setPixelColor(30, NEO.Color(0, 255, 255));
NEO.setPixelColor(31, NEO.Color(0, 255, 255));
NEO.setPixelColor(32, NEO.Color(0, 255, 255));
NEO.setPixelColor(33, NEO.Color(0, 255, 255));
NEO.setPixelColor(34, NEO.Color(0, 255, 255));
D7 = digitalRead(S7);
if (D7 == LOW) {
NEO.setPixelColor(35, NEO.Color(0, 255, 255));
NEO.setPixelColor(36, NEO.Color(0, 255, 255));
NEO.setPixelColor(37, NEO.Color(0, 255, 255));
NEO.setPixelColor(38, NEO.Color(0, 255, 255));
NEO.setPixelColor(39, NEO.Color(0, 255, 255));
NEO.setPixelColor(40, NEO.Color(0, 255, 255));
D8 = digitalRead(S8);
if (D8 == LOW) {
NEO.setPixelColor(41, NEO.Color(0, 255, 255));
NEO.setPixelColor(42, NEO.Color(0, 255, 255));
NEO.setPixelColor(43, NEO.Color(0, 255, 255));
NEO.setPixelColor(44, NEO.Color(0, 255, 255));
NEO.setPixelColor(45, NEO.Color(0, 255, 255));
while(true);
PT_END(pt);
Code WHITOUT ProtoThreads Library ITS WORKS
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
int NA = 16;
int NB = 16;
int MQ9= 10;
int Posicion = NA;
lcd.backlight();
lcd.init();
MQ9=analogRead(A1);
lcd.setCursor(0,1);
lcd.print(T2);
lcd.print(MQ9);
delay(200);
lcd.clear();
Posicion--;
Final++;
Inicio = Final = 0;
Posicion = NA;
Inicio++;
else {
Inicio++;
Final++;
