Is it possible to make something that a digitalRead() command is reading a variable? Not a pin?
My problem is, i want too add an ability to a library and can't alter the library because of lack of knowing and future updates.
The library itself uses "digitalRead(thePin)" to get its value.
Any way to provide a boolean variable to that? Or create something like virtual pins and define a value for them?
As long as the variable contains a valid pin number, a variable should work fine. What makes you think it wouldn't?
KeithRB:
It should not contain a pin number, it should "simulate" an input
I would like to use for example
somevar = HIGH
digitalRead(somevar) should then return high or low
system
April 3, 2017, 6:39pm
4
No. You can't do that. The digitalRead() function takes a pin number and reads the physical hardware. You can't "emulate" the digitalRead() function without the library being aware of the emulation.
Then I would put a wrapper around digital read:
int myDitigalRead(int var)
if (var == -1) return LOW;
if (var == -2) return HIGH;
return DigitalRead(var);
You have to be careful because HIGH and LOW are valid pin numbers.
system
April 3, 2017, 6:44pm
6
That would require a modification to the existing library, which OP seems unwilling, or unable, to modify.
Does the library return the value it reads or does it do something with the value read ?
More details of what you are trying to do would help considerably.
