Proximity sensor through a glass + triggers lighting system
Hi all,
I am new in this forum and after checking previous post, I haven't found an answer to my problem. I have a client who wants to have a proximity sensor on the storefront to detect when a viewer passes near by. When the sensor detects this viewer, it should trigger the lighting system to work and change the lighting scene. So basically what I am looking for is a proximity sensors which work through a glass (the glass is around 12mm thick) and also a controller which sends this trigger signal by GPIO or IP. Would you know a solution like that? Would you please help me with that?
Any help would be very appreciated.
Priximity swiches detect metal at a distance of a few millimeters.
Ultra sonics doesnt't work through glass.
No problem.
Radar sensors.
Just one warning.
Unless you place a reflector plate an inch or two behind it, it will detect both front and back, through glass and most walls.
