Hello
hi, iam very very green and would really appreciate any help at all !!
My plan seems simple but i just cant seem to get it to work.
i want to use these proximity sensors (www.oceancontrols.com.au/datasheet/ibe/IBx-xxx_datasheet.pdf)
to trigger audio clips in Live using the maxuino & the mega 2560.
just not sure how to setup maxuino or live?
do i need to add the mega as a midi input?
and how can i map the incoming signal to trigger the clips?
the proximity sensors need 10v, and send out a ?200mA
i found someone who has used something around about the same and they say to put;
27k resistor from sensor output to Arduino input pin
10k resistor from Arduino input pin to ground
what do you think?
Here are the particulars:
Arduino MEGA AT mega 2560
IBEST proximity sensors cps-12n04b
cant seem to find any info on how to config this
thank you in advance !!!!!
