Hi
I need to read some form of proximity sensor and found one at ebay but it has an Whopping 320KHz TTL npn puls as output. Is it possible to read that high frequency with Arduino?
is it one puls or a continuous stream?
A link to a datasheet would be nice
A link to the ebay site would too be helpfull
First word that came up in my mind was "interrupt"
This is the facts taken from Ebay. They didnt have any datasheet. Interupt can read signals like this I know but my question was if the Arduino can read so fast pulses as 320KHz or is it that the sensor can read as fast as 320KHz pulses before read error?
Features :
100% Brand New
This hall sensor is determined by the voltage regulator, Hall-voltage generator, differential amplifier, Schmitt trigger, and a collector of output is composed of magnetic sensors, enter it as the magnetic flux density, output is a digital signal.
Characteristics:
Wide supply voltage range
High frequency
Long life, small size, easy to install
Direct and TTL.MOS and transistor logic circuit interface
Product Details:
Model: NJK-5002C
Appearance: M12mm cylinders
Output type: NPN 3-wires normally open
Detection range: 10MM
Power supply voltage: 6-36VDC
Output current: 200mA
Detected objects: magnet
Switching frequency: 320KHZ
Shell material: copper
Package
100% Brand New
Hall Effect Hall sensor Proximity Switch NPN 3-wires normally open+ magnet x 1
