Ja, immer mit der DallasTemperature.h
Mit diesem Sketch kannst Du DS..... suchen:
#include <DallasTemperature.h>
#include <OneWire.h>
#include <SoftwareSerial.h>
// LCD=======================================================
//Bibliothek initialisieren
/* DS18S20 Temperaturchip i/o */
OneWire ds(17); // on pin 9
#define MAX_DS1820_SENSORS 17
byte addr[MAX_DS1820_SENSORS][8];
void setup(void)
if (!ds.search(addr[0]))
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
if ( !ds.search(addr[1]))
ds.reset_search();
delay(250);
return;
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
char buf[20];
void loop(void)
byte i, sensor;
byte present = 0;
byte data[12];
for (sensor=0;sensor<MAX_DS1820_SENSORS;sensor++)
if ( OneWire::crc8( addr[sensor], 7) != addr[sensor][7])
Serial.println("CRC is not valid");
return;
if ( addr[sensor][0] != 0x10)
Serial.println("Device is not a DS18S20 family device.");
return;
ds.reset();
ds.select(addr[sensor]);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++)
{ // we need 9 bytes
data[i] = ds.read();
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (TReading*100/2);
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
sprintf(buf, "%d:%c%d.%d\337C ",sensor,SignBit ? '-' : '+', Whole, Fract < 10 ? 0 : Fract);
Serial.println(buf);
Mit diesem die IDs auslesen und anzeigen:
OneWire ow(10);
void setup(void)
lookUpSensors();
void lookUpSensors()
byte address[8];
int i=0;
byte ok = 0, tmp = 0;
Serial.println("--Suche gestartet--");
while (ow.search(address))
tmp = 0;
//0x10 = DS18S20
if (address[0] == 0x10)
Serial.print("Device is a DS18S20 or DS1820: ");
tmp = 1;
//0x28 = DS18B20
if (address[0] == 0x28)
Serial.print("Device is a DS18B20 : ");
tmp = 1;
//display the address, if tmp is ok
if (tmp == 1)
if (OneWire::crc8(address, 7) != address[7])
Serial.println("but it doesn't have a valid CRC!");
//all is ok, display it
for (i=0;i<8;i++)
if (address[i] < 9)
Serial.print("0");
Serial.print("0x");
Serial.print(address[i],HEX);
if (i<7)
Serial.print(", ");
Serial.println("");
ok = 1;
}//end if tmp
}//end while
if (ok == 0)
Serial.println("Keine Sensoren gefunden");
Serial.println("--Suche beendet--");
void loop(void)
//do nothing :)
// delay(1000);
// setup();
Und mit diesem einzelne DS.... am Bus byIndex
//Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
//Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
//Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
//"Dallas Temperature IC Control Library Demo“);
//Start up the library
//sensors.begin();
void loop(void)
Serial.println("DS1b20_1 Sketch");
sensors.requestTemperatures(); //to issue a global temperature
//request to all devices on the bus
Serial.println("Requesting temperatures");
sensors.requestTemperatures(); //Send the command to get temperatures
Serial.print("Temperature for Device 1 is: ");
Serial.println(sensors.getTempCByIndex(0));
delay(750);
Serial.println("DONE");
Serial.print("Temperature for Device 2 is: ");
Serial.println(sensors.getTempCByIndex(1));
delay(750);
Serial.print("Temperature for Device 3 is: ");
Serial.println(sensors.getTempCByIndex(2));
delay(750);
Serial.print("Temperature for Device 4 is: ");
Serial.println(sensors.getTempCByIndex(3));
delay(750);
Serial.print("Temperature for Device 5 is: ");
Serial.println(sensors.getTempCByIndex(4));
delay(750);
delay(3000);
//Why „byIndex“? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
Wobei 0 der 1. am Bus ist, 1 der 2. usw.
