Hello everyone,
I started interesting in Arduino just recently (around a week ago) and am quickly getting in love with the Pro Micro’s I’m using for testing and playing around.
I am a gamer and wanted to build my own battlestation with button boxes and custom made peripherals.
So far I realized a small button box with an analog stick salvaged from a broken gamepad and I am hapy so far.
I decided to raise up the notch by building a new button box with an arcade trackball (like the Missile Command cabinet control) I found online that uses PS/2 conection.
I messed around with knowledge and scripts found on the net and managed to make it work flawlessly to move my mouse cursor. But that’s just the first step: I’d like to include the trackball in a HID recognized as a gamepad in the windows joy.cpl and maybe exploit the photosensors pulses as digital inputs, like simple button presses.
The problem is when I try to include both Mouse.h and Joystick.h: the IDE monitor doesn’t give any prints anymore and the cursor stops moving.
Following the code I’m using prior the Joystick.h include.
I would love to receive any hint leading to the right path and I apologize about my post, I am not quite used to forums etiquette.
Thanks in advance!
* an arduino sketch to interface with a ps/2 mouse.
* Also uses serial protocol to talk back to the host
* and report what it finds.
* Pin 5 is the mouse data pin, pin 6 is the clock pin
* Feel free to use whatever pins are convenient.
#include <Mouse.h>
#define MDATA 5
#define MCLK 6
* according to some code I saw, these functions will
* correctly set the mouse clock and data pins for
* various conditions.
void gohi(int pin)
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);
void golo(int pin)
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
void mouse_write(char data)
char i;
char parity = 1;
// Serial.print("Sending ");
// Serial.print(data, HEX);
// Serial.print(" to mouse\n");
// Serial.print("RTS");
/* put pins in output mode */
gohi(MDATA);
gohi(MCLK);
delayMicroseconds(300);
golo(MCLK);
golo(MDATA);
delayMicroseconds(10);
/* start bit */
gohi(MCLK);
/* wait for mouse to take control of clock); */
while (digitalRead(MCLK) == HIGH)
/* clock is low, and we are clear to send data */
for (i=0; i < 8; i++) {
if (data & 0x01) {
gohi(MDATA);
else {
golo(MDATA);
/* wait for clock cycle */
while (digitalRead(MCLK) == LOW)
parity = parity ^ (data & 0x01);
data = data >> 1;
/* parity */
if (parity) {
gohi(MDATA);
else {
golo(MDATA);
/* stop bit */
gohi(MDATA);
delayMicroseconds(50);
/* wait for mouse to switch modes */
while ((digitalRead(MCLK) == LOW) || (digitalRead(MDATA) == LOW))
/* put a hold on the incoming data. */
golo(MCLK);
// Serial.print("done.\n");
* Get a byte of data from the mouse
char mouse_read(void)
char data = 0x00;
int i;
char bit = 0x01;
// Serial.print("reading byte from mouse\n");
/* start the clock */
gohi(MCLK);
gohi(MDATA);
delayMicroseconds(5); /* not sure why */
while (digitalRead(MCLK) == LOW) /* eat start bit */
if (digitalRead(MDATA) == HIGH) {
data = data | bit;
bit = bit << 1;
/* eat parity bit, which we ignore */
/* eat stop bit */
golo(MCLK);
// Serial.print("Recvd data ");
// Serial.print(" from mouse\n");
return data;
void mouse_init()
gohi(MCLK);
gohi(MDATA);
// Serial.print("Sending reset to mouse\n");
mouse_write(0xff);
mouse_read(); /* ack byte */
// Serial.print("Read ack byte1\n");
mouse_read(); /* blank */
// Serial.print("Sending remote mode code\n");
mouse_write(0xf0); /* remote mode */
mouse_read(); /* ack */
// Serial.print("Read ack byte2\n");
delayMicroseconds(100);
mouse_init();
Mouse.begin();
* get a reading from the mouse and report it back to the
* host via the serial line.
char mstat;
char mx;
char my;
/* get a reading from the mouse */
mouse_write(0xeb); /* give me data! */
mouse_read(); /* ignore ack */
mstat = mouse_read();
mx = mouse_read();
my = mouse_read();
Mouse.move(mx, -my, 0);
//delay(2);
/* send the data back up */
Serial.print(mstat, BIN);
Serial.print("\tX=");
Serial.print(mx, DEC);
Serial.print("\tY=");
Serial.print(my, DEC);
delay(20); /* twiddle */
