hi guys
i have a problem....
i am trying to run this code...
/* PSX Controller Decoder Library (Psx.pde)
Written by: Kevin Ahrendt June 22nd, 2008
Controller protocol implemented using Andrew J McCubbin's analysis.
http://www.gamesx.com/controldata/psxcont/psxcont.htm
Shift command is based on tutorial examples for ShiftIn and ShiftOut
functions both written by Carlyn Maw and Tom Igoe
http://www.arduino.cc/en/Tutorial/ShiftIn
http://www.arduino.cc/en/Tutorial/ShiftOut
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <Psx.h> // Includes the Psx Library
#define dataPin 2
#define cmndPin 3
#define attPin 4
#define clockPin 5
#define LEDPin 13
Psx Psx; // Initializes the library
unsigned int data = 0; // data stores the controller response
Psx.setupPins(dataPin, cmndPin, attPin, clockPin, 10); // Defines what each pin is used
// (Data Pin #, Cmnd Pin #, Att Pin #, Clk Pin #, Delay)
// Delay measures how long the clock remains at each state,
// measured in microseconds.
pinMode(LEDPin, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
data = Psx.read(); // Psx.read() initiates the PSX controller and returns
// the button data
if (data & psxR2) // If the data anded with a button's hex value is true,
// it signifies the button is pressed. Hex values for each
// button can be found in Psx.h
digitalWrite(LEDPin, HIGH); // If button is pressed, turn on the LED
digitalWrite(LEDPin, LOW); // If the button isn't pressed, turn off the LED
but get this error when i go to upload.....
c:/documents and settings/skip56/desktop/v4/arduino-0017/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
c:/documents and settings/skip56/desktop/v4/arduino-0017/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected `)' before 'int'
can anybody help ???
many thanks
Skip
