Hi there,
I am controlling my robot with PS controller. I am using 2 motor driver and one of them is l293d. i Wrote following code to control my robot.
#include <PS2X_lib.h>
#define pressures true
#define rumble true
byte vibrate = 0;
PS2X ps2x;
int error = 0;
int type = 0;
int l_speed = 50;
int m_speed1 = 100;
int m_speed2 = 150;
int h_speed = 255;
int Speed = 70;
int LX; //Variables for reading stick values
int LY;
int RX;
int RY;
int L_DIR = 14; //Pins For left side of motor
int L_PWM = 10;
int L_BRK = 15;
int R_DIR = 16; //Pins for right side of motor
int R_PWM = 11;
int R_BRK = 17;
int enable = 6;
int i1 = 5; //for gripper motor
int i2 = 4;
int i3 = 3; //for gripper up down motor
int i4 = 2;
int StopperUp = 1;
int StopperDown = 18;
int gripperStopper = 19;
int readUp;
int readDown;
void rotateclockwise(unsigned int );
void rotateanticlockwise(unsigned int );
void l_forward(unsigned int );
void l_backward(unsigned int );
void r_forward(unsigned int );
void r_backward(unsigned int );
void run(void);
void gripperStop(void)
digitalWrite(i1, LOW);
digitalWrite(i2, LOW);
void upDownStop(void)
digitalWrite(i3, LOW);
digitalWrite(i4, LOW);
/*void gripperOpen()
if(digitalRead(gripperStopper) != HIGH)
digitalWrite(i2, HIGH);
gripperStop();
void gripperClose(void)
digitalWrite(i1, HIGH);
/*void gripperUp(void)
if(digitalRead(StopperUp) != HIGH && digitalRead(StopperDown) == HIGH)
digitalWrite(i4, HIGH);
upDownStop();
void gripperDown(void)
if(digitalRead(StopperDown) != HIGH && digitalRead(StopperUp) == HIGH)
digitalWrite(i3, HIGH);
upDownStop();
delay(300);
pinMode(L_DIR, OUTPUT);
pinMode(L_PWM, OUTPUT);
pinMode(L_BRK, OUTPUT);
pinMode(R_DIR, OUTPUT);
pinMode(R_PWM, OUTPUT);
pinMode(R_BRK, OUTPUT);
pinMode(enable, OUTPUT);
pinMode(i1, OUTPUT);
pinMode(i2, OUTPUT);
pinMode(i3, OUTPUT);
pinMode(i4, OUTPUT);
pinMode(gripperStopper, OUTPUT);
pinMode(StopperUp, OUTPUT);
pinMode(StopperDown, OUTPUT);
digitalWrite(enable, HIGH);
//setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
error = ps2x.config_gamepad(9,8,7,12,pressures,rumble);
if(error == 1) //skip loop if no controller found
return;
digitalWrite(L_BRK, HIGH);
digitalWrite(R_BRK, HIGH);
upDownStop();
gripperStop();
ps2x.read_gamepad(false, vibrate);
//code for l293d
if(ps2x.Button(PSB_L1))
//gripperOpen();
else if(ps2x.Button(PSB_L2))
//gripperClose();
else if(ps2x.Button(PSB_PAD_UP))
else if(ps2x.Button(PSB_PAD_DOWN))
//Code for bot movement
LY = ps2x.Analog(PSS_LY);
delay(5);
LX = ps2x.Analog(PSS_LX);
delay(5);
RY = ps2x.Analog(PSS_RY);
delay(5);
RX = ps2x.Analog(PSS_RX);
delay(5);
if(ps2x.ButtonPressed(PSB_CROSS))
Speed = l_speed;
else if(ps2x.ButtonPressed(PSB_SQUARE))
Speed = m_speed1;
else if(ps2x.ButtonPressed(PSB_CIRCLE))
Speed = m_speed2;
else if(ps2x.ButtonPressed(PSB_TRIANGLE))
Speed = h_speed;
if(LY < 127 && LX == 128)
while(LY < 127 && LX == 128)
run();
Speed = l_speed;
Speed = m_speed1;
Speed = m_speed2;
Speed = h_speed;
LY = map(LY, 0, 127, 0, Speed);
LY = Speed - LY;
//l_forward(LY);
//r_forward(LY);
digitalWrite(L_DIR, LOW);
analogWrite(L_PWM, LY);
delay(5);
digitalWrite(R_DIR, LOW);
analogWrite(R_PWM, LY);
delay(5);
ps2x.read_gamepad();
else if(LY > 127 && LX == 128)
while(LY > 127 && LX == 128)
run();
Speed = l_speed;
Speed = m_speed1;
Speed = m_speed2;
Speed = h_speed;
LY = map(LY, 128, 255, 0, Speed);
//l_backward(LY);
//r_backward(LY);
digitalWrite(L_DIR, HIGH);
delay(5);
digitalWrite(R_DIR, HIGH);
delay(5);
else if(RX < 128 && RY == 127)
while(RX < 128 && RY == 127)
run();
Speed = l_speed;
Speed = m_speed1;
Speed = m_speed2;
Speed = h_speed;
RX = map(RX, 0, 127, 0, Speed);
RX = Speed - RX;
rotateanticlockwise(RX);
else if(RX > 128 && RY == 127)
while(RX > 128 && RY == 127)
run();
Speed = l_speed;
Speed = m_speed1;
Speed = m_speed2;
Speed = h_speed;
RX = map(RX, 128, 255, 0, Speed);
rotateclockwise(RX);
gripperStop();
upDownStop();
void l_forward(unsigned int ly)
analogWrite(L_PWM, ly);
delay(5);
void r_forward(unsigned int ly)
analogWrite(R_PWM, ly);
delay(5);
void l_backward(unsigned int ly)
delay(5);
void r_backward(unsigned int ly)
delay(5);
void rotateclockwise(unsigned int ly)
l_forward(ly);
r_backward(ly);
delay(5);
void rotateanticlockwise(unsigned int ly)
r_forward(ly);
l_backward(ly);
delay(5);
void run()
digitalWrite(L_BRK, LOW);
digitalWrite(R_BRK, LOW);
using joystick bot is moving fine but when i press up button, ps2 controller reconnects and motor starts moving itself and weird things start happenings. If i remove the Code for l293d everything is working fine
as soon as i added the l293d problem started happening. Is there any problem with the code?
