Ps2 tank motors not working
im quite new to thi sim trying to make a rc tank with a ps2 controller and l298n, i cant seem to get the motors turning correctly, they only turn one way and only on one side , thanks
#include <PS2X_lib.h>  //for v1.6
// servo pins
#include<Servo.h> //jamies code
int pos = 90;
Servo s1;
Servo s2;
//motor pins
#define enA 9
#define in1 4
#define in2 12
#define enB 6
#define in3 13
#define in4 7
//contoller pins
#define PS2_DAT        A0  //14
#define PS2_CMD        A1 //15
#define PS2_SEL        A2  //16
#define PS2_CLK        A3  //17
//define motor speeds on start
int motorSpeedA = 0;
int motorSpeedB = 0;
 * select modes of PS2 controller:
 *   - pressures = analog reading of push-butttons
 *   - rumble    = motor rumbling
 * uncomment 1 of the lines for each mode selection
//#define pressures   true
#define pressures   false
//#define rumble      true
#define rumble      true
PS2X ps2x; // create PS2 Controller Class
//right now, the library does NOT support hot pluggable controllers, meaning
//you must always either restart your Arduino after you connect the controller,
//or call config_gamepad(pins) again after connecting the controller.
int error = 0;
byte type = 0;
byte vibrate = 0;
void setup(){
  Serial.begin(57600);
// servo pins
{ s1.attach(3);          //Servo motor attached to pin 3
  s1.write(pos);
  s2.attach(5);          //
  s2.write(pos);}
   pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  delay(300);  //added delay to give wireless ps2 module some time to startup, before configuring it
  //CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
  //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble);
  if(error == 0){
    Serial.print("Found Controller, configured successful ");
    Serial.print("pressures = ");
	if (pressures)
	  Serial.println("true ");
	  Serial.println("false");
	Serial.print("rumble = ");
	if (rumble)
	  Serial.println("true)");
    Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
    Serial.println("holding L1 or R1 will print out the analog stick values.");
    Serial.println("Note: Go to www.billporter.info for updates and to report bugs.");
  else if(error == 1)
    Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
  else if(error == 2)
    Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
  else if(error == 3)
    Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
//  Serial.print(ps2x.Analog(1), HEX);
  type = ps2x.readType();
  switch(type) {
    case 0:
      Serial.print("Unknown Controller type found ");
    case 1:
      Serial.print("DualShock Controller found ");
  /* You must Read Gamepad to get new values and set vibration values
     ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255)
     if you don't enable the rumble, use ps2x.read_gamepad(); with no values
     You should call this at least once a second
 { //DualShock Controller
    ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
    if(ps2x.Button(PSB_START))         //will be TRUE as long as button is pressed
      Serial.println("Start is being held");
    if(ps2x.Button(PSB_SELECT))
      Serial.println("Select is being held");
    if(ps2x.Button(PSB_PAD_UP)) {      //will be TRUE as long as button is pressed
      Serial.print("Up held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_UP), DEC);
    if(ps2x.Button(PSB_PAD_RIGHT)){
      Serial.print("Right held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_RIGHT), DEC);
    if(ps2x.Button(PSB_PAD_LEFT)){
      Serial.print("LEFT held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_LEFT), DEC);
    if(ps2x.Button(PSB_PAD_DOWN)){
      Serial.print("DOWN held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_DOWN), DEC);
    vibrate = ps2x.Analog(PSAB_CROSS);  //this will set the large motor vibrate speed based on how hard you press the blue (X) button
    if (ps2x.NewButtonState()) {        //will be TRUE if any button changes state (on to off, or off to on)
      if(ps2x.Button(PSB_L3))
        Serial.println("L3 pressed");
      if(ps2x.Button(PSB_R3))
        Serial.println("R3 pressed");
      if(ps2x.Button(PSB_L2))
        Serial.println("L2 pressed");
      if(ps2x.Button(PSB_R2))
        Serial.println("R2 pressed");
      if(ps2x.Button(PSB_TRIANGLE))
        Serial.println("Triangle pressed");
    if(ps2x.ButtonPressed(PSB_CIRCLE))               //will be TRUE if button was JUST pressed
      Serial.println("Circle just pressed");
    if(ps2x.NewButtonState(PSB_CROSS))               //will be TRUE if button was JUST pressed OR released
      Serial.println("X just changed");
    if(ps2x.ButtonReleased(PSB_SQUARE))              //will be TRUE if button was JUST released
      Serial.println("Square just released");
    if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) { //print stick values if either is TRUE
      Serial.print("Stick Values:");
      Serial.print(ps2x.Analog(PSS_LY), DEC); //Left stick, Y axis. Other options: LX, RY, RX
      Serial.print(",");
      Serial.print(ps2x.Analog(PSS_LX), DEC);
      Serial.print(",");
      Serial.print(ps2x.Analog(PSS_RY), DEC);
      Serial.print(",");
      Serial.println(ps2x.Analog(PSS_RX), DEC);
  delay(50);
  // Y-axis used for forward and backward control
  if (ps2x.Analog(PSS_LY) < 125) {
    // Set Motor A backward
    digitalWrite(in1, HIGH);
    digitalWrite(in2, LOW);
    // Set Motor B backward
    digitalWrite(in3, HIGH);
    digitalWrite(in4, LOW);
    // Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
    motorSpeedA = map((PSS_LY), 125, 0, 0, 255);
    motorSpeedB = map((PSS_LY), 125, 0, 0, 255);
  else if ((PSS_LY) > 131) {
    // Set Motor A forward
    digitalWrite(in1, LOW);
    digitalWrite(in2, HIGH);
    // Set Motor B forward
    digitalWrite(in3, LOW);
    digitalWrite(in4, HIGH);
    // Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
    motorSpeedA = map((PSS_LY), 131, 255, 0, 255);
    motorSpeedB = map((PSS_LY), 131, 255, 0, 255);
  // If joystick stays in middle the motors are not moving
  else {
    motorSpeedA = 0;
    motorSpeedB = 0;
  // X-axis used for left and right control
  if ((PSS_LX) < 125) {
    // Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
    int xMapped = map((PSS_LX), 125, 0, 0, 255);
    // Move to left - decrease left motor speed, increase right motor speed
    motorSpeedA = motorSpeedA - xMapped;
    motorSpeedB = motorSpeedB + xMapped;
    // Confine the range from 0 to 255
    if (motorSpeedA < 0) {
      motorSpeedA = 0;
    if (motorSpeedB > 255) {
      motorSpeedB = 255;
  if ((PSS_LX) > 131) {
    // Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
    int xMapped = map((PSS_LX), 131, 255, 0, 255);
    // Move right - decrease right motor speed, increase left motor speed
    motorSpeedA = motorSpeedA + xMapped;
    motorSpeedB = motorSpeedB - xMapped;
    if (motorSpeedA > 255) {
      motorSpeedA = 255;
    if (motorSpeedB < 0) {
      motorSpeedB = 0;
  // Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
  if (motorSpeedA < 70) {
    motorSpeedA = 0;
  if (motorSpeedB < 70) {
    motorSpeedB = 0;
  analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
  analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
  if(ps2x.Analog(PSS_RY) >= 129)
  if(pos <=180)
    pos = pos + map(ps2x.Analog(PSS_RY), 129, 255, 1, 8);
    s2.write(pos);
else if(ps2x.Analog(PSS_RY) <= 127)
  if(pos >= 0)
    pos =pos -map(ps2x.Analog(PSS_RY), 127, 0, 1, 8);
  s2.write(pos);
if((PSS_RX) >= 129)
  if(pos <= 180)
  pos = pos + map(PSS_RX, 129, 255, 1, 8);
  s1.write(pos);
else if(PSS_RX <= 127)
  if(pos >= 0)
   pos = pos - map(PSS_RX, 127, 0, 1, 8);
   s1.write(pos);
Post an annotated schematic showing exactly how you have wired it. Be sure to show power, ground, power sources and note any lead over 10"/25cm.
When you post a wiring diagram, verify your wiring agrees with the drawing and the sketch.
The power supply you use is probably the cause, and your motor driver board is using much of the energy.
Try this sketch. If the power supply is the issue, this can be resolved by more capacity. The sketch has eight sections. The first four functions drives ONE motor at a time in one direction. Watch the serial monitor output.
CHANGE THE PIN VALUES IN THIS SKETCH TO MATCH YOUR PROJECT
// Motor steering simulating Arduino Cars with L298N style motor driver boards
// NOT for LAFVIN car (LDR, IR, SONAR, line follow, IRremote)
// LEFT motor
int IN1 = 8; // LEFT motor forward, DIO pin, only HIGH or LOW
int IN2 = 7; // LEFT REVERSE, DIO pin, only HIGH or LOW
int ENA = 6; // ENABLE (and disable) left motor, PWM pin, speed = 0 - 255
// RIGHT motor
int IN3 = 2; // RIGHT motor forward, DIO pin, only HIGH or LOW
int IN4 = 4; // RIGHT motor reverse, DIO pin, only HIGH or LOW
int ENB = 3; // ENABLE (and disable) right motor, PWM pin, speed = 0 - 255
// adjustable PWM, range 0 (no speed) - 255 (full speed)
// useful factors of 255 = 1, 3, 5, 15, 17, 51, 85...
int speed =  51; // slow
// int speed = 127; // medium
// int speed = 255; // maximum
int ON  = speed;
int OFF = 0;
int thisDelay = 3000; // delay during motor movement
  Serial.begin(9600); // for Serial Monitor
  pinMode(ENA, OUTPUT); // configure ENABLE pins for output
  pinMode(ENB, OUTPUT);
  pinMode(IN1, OUTPUT); // configure MOTOR DRIVER pins for output
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  digitalWrite(ENA, speed); // PWM speed control, 0 - 255
  digitalWrite(ENB, speed);
  eightSteeringModes();
void basicSteering() {
  enableMotors(ON);
  forward(); delay(1000); allStop();
  reverse(); delay(1000); allStop();
  rotateLeft(); delay(1000); allStop();
  rotateRight(); delay(1000); allStop();
  enableMotors(OFF);
void eightSteeringModes () {
  enableMotors(ON);
  allStop();
  // single motor
  forwardSkidLeft();
  reverseSkidRight();// placed this out of order to keep car stationary
  forwardSkidRight();
  reverseSkidLeft();
  // double motors
  rotateLeft();
  rotateRight();
  forward();
  reverse();
  allStop();
  enableMotors(OFF);
// L298N MOTOR DIRECTIONS
//  ENA   ENB   IN1   IN2   IN3   IN4
//  HIGH  HIGH  HIGH  LOW   LOW   HIGH  forward - left forward, right forward
//  HIGH  HIGH  LOW   HIGH  HIGH  LOW   reverse - left reverse, right reverse
//  HIGH  HIGH  LOW   HIGH  LOW   HIGH  face left - left reverse, right forward
//  HIGH  HIGH  HIGH  LOW   HIGH  LOW   face right - left forward, right reverse
//  HIGH  HIGH  HIGH  LOW   LOW   LOW   skid left - stop left, forward right
//  HIGH  HIGH  LOW   LOW   LOW   LOW   stop - all LOW
//  HIGH  HIGH  HIGH  HIGH  HIGH  HIGH  brake - all HIGH - do not use, over current
//  LOW   LOW   N/A   N/A   N/A   N/A   stop - both ENABLE LOW
// *** LEFT motor and RIGHT motor are facing opposite directions ***
// *** LEFT motor will use HIGH, LOW to go forward ***
// *** RIGHT motor will use LOW, HIGH to go forward ***
// MOTOR FUNCTIONS
void driveMotor(bool p1, bool p2, bool p3, bool p4) {
  digitalWrite(IN1, p1);
  digitalWrite(IN2, p2);
  digitalWrite(IN3, p3);
  digitalWrite(IN4, p4);
  delay(thisDelay);
void enableMotors(int enab) {
  if (enab) {
    Serial.print("Enable motors... ");
    delay(thisDelay / 2);
    Serial.print("... Disable motors.");
  digitalWrite(ENA, enab);
  digitalWrite(ENB, enab);
void allStop() {
  Serial.print("All motors Stop. (L STOP R STOP)");
  driveMotor(LOW, LOW, LOW, LOW);
  delay(thisDelay / 2); // allow motor to be stopped
void forwardSkidLeft() {
  Serial.print("\n\tForward Skid-Left.  (L STOP R FWD)");
  digitalWrite(ENA, 0);
  driveMotor(LOW, LOW, LOW, HIGH); // left motor stop, right motor forward
void forwardSkidRight() {
  Serial.print("\tForward Skid-Right. (L FWD R STOP)");
  digitalWrite(ENB, 0);
  driveMotor(HIGH, LOW, LOW, LOW); // left motor forward, right motor off
void reverseSkidLeft()  {
  Serial.print("\tReverse Skid-Left.   (L REV R STOP)\n");
  driveMotor(LOW, HIGH, LOW, LOW); // left motor reverse, right motor stop
void reverseSkidRight() {
  Serial.print("\tReverse Skid-Right.  (L STOP R REV)\n");
  driveMotor(LOW, LOW, HIGH, LOW); // left motor off, right motor reverse
void rotateLeft() {
  Serial.print("\tRotate Left.\t    (L REV R FWD)");
  driveMotor(LOW, HIGH, LOW, HIGH); // left motor reverse, right motor forward
void rotateRight() {
  Serial.print("\tRotate Right.\t     (L FWD R REV)\n");
  driveMotor(HIGH, LOW, HIGH, LOW); // left motor forward, right motor reverse
void forward() {
  Serial.print("\tForward.\t    (L FWD R FWD)");
  driveMotor(HIGH, LOW, LOW, HIGH); // left motor forward, right motor forward
void reverse() {
  Serial.print("\tReverse.\t     (L REV R REV)\n");
  driveMotor(LOW, HIGH, HIGH, LOW ); // left motor reverse, right motor reverse
void pwmDrive() {
  // Move motor with changing speed
  int dutyCycle;
  forward();
  while (dutyCycle <= 255) {
    digitalWrite(ENA, dutyCycle);
    dutyCycle += 51; // useful factors of 255 = 1, 3, 5, 15, 17, 51, 85
    delay(250);
  reverse();
  while (dutyCycle > 0) {
    dutyCycle -= 51;
    delay(250);
