PS3 Controller w/ Arduino BT Dongle
Hello,
I believe I am running this code correctly but obviously not.... I am trying to find the mac address for the dongle I am running. I am getting the following error in the serial monitor after I upload it/verify. "OSC did not start". I am brand new to arduino and the programming language. I have watched a and read a lot on this issue, obviously not enough.... or I have a bad dongle.
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
// PS3BT PS3(&Btd, 0x00, 0x15, 0x83, 0x3D, 0x0A, 0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printTemperature;
bool printAngle;
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nPS3 Bluetooth Library Started"));
