hello. I need a project that works with esp32 PS4 controller. please help
Please give me the codes.
I need a ready-made project. I don't know how to program myself.
(post deleted by author)
No one will have the “code” you need that will fit your project. You need to put in the effort to write the code yourself. We can help you if you have any issues but no one will just give you code that does exactly what you want.
What happens if there is an issue, how would you fix it? Sure, you could come back here and we can play 21 questions to figure out why it doesn’t work but it would be better if you learned how it works so you can fix it.
If you want someone to do all the work for you then perhaps this thread should be moved to Jobs and Paid Consultancy
Here is a Github link to pair a PS4 controller to an ESP32. HERE
I have a ready-made project code, I need to change the gyro module to "mpu6050". Please help.
ESP32_PS4_RC.ino (12,9 КБ)
Do you have the MPU6050 library downloaded and have you run any of the example sketches that come with it?
I downloaded MPU6050 by Electronic Cats, there is an example sketch called MPU6050_Raw. Try it and see if it works.
I don't have a MPU6050 module so I am unable to do any kind of testing on my end.
If the code uses a different gyro, you need to change it to "mpu6050". Do it yourself.
Please
I know there is a language barrier, but I am not going to do your project for you.
Once again, I do not have a MPU6050 module. I can add the libraries, no problem, but I can not test it to make sure it works. YOU need to test it since you have the module.
I am asking you to download the MPU6050 library, run the example sketch called "mpu6050_Raw" and see if it works.
Good advice. You should take it.
If not, please state your budget and required completion date. Tanstaafl!
I have merged your cross-posts @tohir9600.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
