PSNee code error
I’ve been trying to get this code to verify but since I know very little, I can’t seem to get any further.
PSnee_v7_ER.ino (15.3 KB)
When you encounter an error you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
I know.
it's too big to fit
heres a summery
exit status 1
'data' was not declared in this scope
If it’s too big to post in a reply then you save it in a text file and attach it.
The problem is the sketch needs to be configured to your usage by uncommenting one of these lines:
//#define ARDUINO_BOARD
//#define ATTINY_X5
If you had posted the full error output it would have given me the information I would need to tell you which one you need to uncomment but it should be easy enough to figure out. It’s all explained clearly in the comments at the start of the sketch.
I think I tried that
heres the full error
PSNee ER.txt (13.8 KB)
Change line 35 from:
to:
that worked, thanks :3
