Hi everibody, I bought a cheap PS2 compatibile controller in order to use it as an input device for the Arduino. I downloaded the AnalogPSXLibrary(Arduino Playground - AnalogPSXLibrary) from the playground but I couldn't manage to compile it trying lo load an example sketch.
Here are the errors I got:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/stdlib.h:111: error: expected `)' before 'int'
I tried both arduino 016 and 017 with the same result. I took a look at the .cpp and .h files and seems ok to me.
had the same problem and was sure that something odd is going on. After reading the button example I added in the first line
const int ledPin = 13;
The example code psx_analog.pde comprises
#define LEDPin 13
Resulting code which compiles successful is now
#include "Psx_analog.h" // Includes the Psx Library
#define dataPin 14
#define cmndPin 15
#define attPin 16
#define clockPin 17
#define motorup 5
#define motordown 6
#define motorleft 9
#define motorright 10
#define center 127
#define LEDPin 13
Psx Psx; // Initializes the library
Psx.setupPins(dataPin, cmndPin, attPin, clockPin); // Defines what each pin is used
// (Data Pin #, Cmnd Pin #, Att Pin #, Clk Pin #)
Psx.initcontroller(psxAnalog);
pinMode(LEDPin, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
//setup motoroutputs
pinMode(motorup, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
pinMode(motordown, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
pinMode(motorleft, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
pinMode(motorright, OUTPUT); // Establishes LEDPin as an output so the LED can be seen
Serial.println("Raw controller values");
// wait for the long string to be sent
delay(100);
Psx.poll(); // Psx.read() initiates the PSX controller and returns
Serial.print("\n"); // the button data
Serial.print(Psx.Controller_mode, HEX); // prints value as string in hexadecimal (base 16)
Serial.print(Psx.digital_buttons, HEX); // prints value as string in hexadecimal (base 16)
Serial.print(Psx.Right_x, HEX); // prints value as string in hexadecimal (base 16)
Serial.print(Psx.Right_y, HEX); // prints value as string in hexadecimal (base 16)
Serial.print(Psx.Left_x, HEX); // prints value as string in hexadecimal (base 16)
Serial.print(Psx.Left_y, HEX); // prints value as string in hexadecimal (base 16)
if (Psx.digital_buttons & psxR2) // If the data anded with a button's hex value is true,
// it signifies the button is pressed. Hex values for each
// button can be found in Psx.h
digitalWrite(LEDPin, HIGH); // If button is pressed, turn on the LED
digitalWrite(LEDPin, LOW); // If the button isn't pressed, turn off the LED
delay(100);
I don't understand the difference since I'm a beginner with ardunio. Could someone help me out with this?
C is case sensitive so your definition of LEDPin has to match its use exactly. A #define can be thought of as a "search and replace at compile time". Given the following everywhere foo appears (below the define) it will be replaced with 10 by the preprocessor (which runs just before, and part of, the compile of your code). I noticed that the Arduino docs said to stay away from #defines - why? IMO they are better as they don't use any memory (search/replace).
Your code #define foo 10
int var = foo;
Gets turned into this
int var = 10;
Furthermore you should get rid of "const int ledPin = 13;" as it is not being used and just wasting precious memory.
Perhaps this is confusing because the addition of a const at the top fixed the compile error, but put that down to the way the Arduino build environment massages source files before they are compiled.
A solution to the compile problem is to replace #include "WConstants.h"
In Psz_analog.h with this: #include "WProgram.h"
You can use either the #define or the const int to define a constant in your sketch, but not both (for the same constant). and as stated above, it must match the case used later in your code
Why is that? In my understanding a #define is akin to a preprocessor search and replace (no extra mem used) and a global const int actually takes up however much memory the AVR defines as an int.
Please explain!
And also, any idea why the Arduino docs say not to use #define? This is pretty standard practice in my experience.
The compiler treats const int as a constant and optimizes it away away so no RAM is used.
Here is the memory dump ( using avr-objdump) from three versions of the blink example sketch. The only difference is in the way the port is defined.
Values are hex:
Data text bss style used #define 0 378 9 #define pin 13
const int 0 378 9 const int pin=13;
int 2 37e 9 int pin = 13;
As you can see, the int version uses two bytes of RAM and a few extra bytes of code to load the variable. the const int version has an identical footprint to #define. const int is better because the compiler can do type checking.
Arduino examples have used int instead of const int perhaps because it is thought that the former is easier for non-technical people. I do see more examples appearing that use const int and hope this will trend will continue (developing one or two good habits early on is no bad thing)
this is the sketch used, compiled three times with the three variations
//const int ledPin = 13;
//int ledPin = 13; // LED connected to digital pin 13
#define ledPin 13
// initialize the digital pin as an output:
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
del
const float f =3.14 will be exactly the same as #define f 3.14
both of these will use 4 bytes less RAM and 8 bytes less flash then a normal float in a sketch like this:
float f = 3.14; // this uses 4 bytes more RAM
//const float f = 3.14;
//#define f 3.14
Serial.print(f);
Bencao74,
I tried your code and I didn´t get response, nothing happens.
May be I had missed something, do I need to use ACKNOLEDGE in what arduinos pin?
I will be glad for your answer.
