I have a cellular modem connected to my micro-controller that uses AT commands for setting up its network and publishing MQTT messages to a remote broker server. But doing so requires a sequence of about a dozen or so AT commands. I will post them below. Many of these codes are modem specific, but each distinct command terminates with \r\n when using a serial connection to the microcontroller.
After all of the configuration is done PDP context, SSL, MQTT, credentials the message can be published to the remote broker server. Unlike the other AT commands though the manual says enter the publish command which looks something like this to me:
//configure MQTT message AT+QMTPUB=<client_idx>,<msgID>,<qos>,<retain>,<topic>
Serial2.write("AT+QMTPUBEX=1,0,0,0,\"motorbeta\"\r\n");
then the command line moves to a new line. Then enter the MQTT message and press control+Z to send. I have verified this works when connected serially to the modem from my computer and using the modem manufacturer's serial connection software to send the AT commands. Their route does work inside their software (which doesn't require \r\n\ at the end of each command from the user).
But what about when my microcontroller is issuing the AT command? How can I replicate control+Z?
So far all of my code works except when it's time to publish a MQTT message I just get "ERROR". I can publish when I connect to the modem directly and follow the manual's steps but just not with the micro-controller. Does anyone have any ideas on how to get this working?
//checking SIM
Serial2.write("AT+CPIN?\r\n");
while (!Serial2.available()) continue;
while (Serial2.available()) {
char sim = Serial2.read();
Serial.print(sim);
delay(2000);
//"configure a PDP context" AT+QICSGP=<contextID>[,<context_type>,<APN>[,<username>,<password>[,<authentication>]]]
Serial2.write("AT+QICSGP=1,2,\"carrier\",\"\",\"\",0\r\n");
char pdpcontext = Serial2.read();
Serial.print(pdpcontext);
delay(2000);
//PDP activation
Serial2.write("AT+QIACT=1\r\n");
char pdp = Serial2.read();
Serial.print(pdp);
delay(15000);
//check service
Serial2.write("AT+CEREG?\r\n");
char service = Serial2.read();
Serial.print(service);
delay(15000);
//"TLS 1.2" AT+QSSLCFG="sslversion",<SSL_ctxID>[,<SSL_version>]
Serial2.write("AT+QSSLCFG=\"sslversion\",1,3\r\n");
char sslversion = Serial2.read();
Serial.print(sslversion);
delay(2000);
//AT+QSSLCFG="ciphersuite",<SSL_ctxID>[,<cipher_suites>] support all cipher suits
Serial2.write("AT+QSSLCFG=\"ciphersuite\",1,0XFFFF\r\n");
char cipher = Serial2.read();
Serial.print(cipher);
delay(2000);
//AT+QSSLCFG="cacert",<SSL_ctxID>[,<cacertpath >]
Serial2.write("AT+QSSLCFG=\"cacert\",1,\"ca.crt\"\r\n");
char cacrt = Serial2.read();
Serial.print(cacrt);
delay(2000);
//"server authentication only" AT+QSSLCFG="seclevel",<SSL_ctxID>[,<seclevel>]
Serial2.write("AT+QSSLCFG=\"seclevel\",1,1\r\n");
char sslsecurity = Serial2.read();
Serial.print(sslsecurity);
delay(2000);
//AT+QSSLCFG="ignorelocaltime",<SSL_ctxID>[,<ignore_localtime>]
Serial2.write("AT+QSSLCFG=\"ignorelocaltime\",1,1\r\n");
char sslignoretime = Serial2.read();
Serial.print(sslignoretime);
delay(2000);
//configure to MQTT protocol 3.1.1 AT+QMTCFG="version",<client_idx>[,<vsn>]
Serial2.write("AT+QMTCFG=\"version\",1,4\r\n");
char mqttversion = Serial2.read();
Serial.print(mqttversion);
delay(2000);
//AT+QMTCFG="pdpcid",<client_idx>[,<cid>]
Serial2.write("AT+QMTCFG=\"pdpcid\",1,1\r\n");
char mqttpdp = Serial2.read();
Serial.print(mqttpdp);
delay(2000);
//AT+QMTCFG="ssl",<client_idx>[,<SSL_enable>[,<ctx_index>]]
Serial2.write("AT+QMTCFG=\"ssl\",1,1,1\r\n");
char mqttssl = Serial2.read();
Serial.print(mqttssl);
delay(2000);
//AT+QMTCFG="keepalive",<client_idx>[,<keep_alive_time>]
Serial2.write("AT+QMTCFG=\"keepalive\",1,3600\r\n");
char mqttalive = Serial2.read();
Serial.print(mqttalive);
delay(2000);
//AT+QMTCFG="session",<client_idx>[,<clean_session>]
Serial2.write("AT+QMTCFG=\"session\",1,1\r\n");
char mqttclean = Serial2.read();
Serial.print(mqttclean);
delay(2000);
Serial2.write("AT+QMTOPEN=1,\"server address\",8883\r\n"); //"This command opens a network for MQTT client." AT+QMTOPEN=<client_idx>,<host_name>,<port>
char mqttopen = Serial2.read();
Serial.print(mqttopen);
delay(10000);
Serial2.write("AT+QMTOPEN?\r\n"); //"This command opens a network for MQTT client." AT+QMTOPEN=<client_idx>,<host_name>,<port>
char mqttopenyn = Serial2.read();
Serial.print(mqttopenyn);
delay(2000);
//AT+QMTCONN=<client_idx>,<clientID>[,<username>[,<password>]]
Serial2.write("AT+QMTCONN=1,\"test\",\"user\",\"password\"\r\n");
char mqttcredentials = Serial2.read();
Serial.print(mqttcredentials);
delay(2000);
Serial2.write("AT+QMTPUBEX=1,0,0,0,\"topic\"\r\n");
char mqttpublishtopic = Serial2.read();
Serial.print(mqttpublishtopic);
delay(2000);
//publish MQTT message
Serial2.write("\"test\"\r\n");
char mqttmessage = Serial2.read();
Serial.print(mqttmessage);
delay(2000);
//disconnect from MQTT server
Serial2.write("AT+QMTDISC=1\r\n");
char mqttserverdisconnect = Serial2.read();
Serial.print(mqttserverdisconnect);
delay(2000);
//disconnect from MQTT network
Serial2.write("AT+QMTCLOSE=1\r\n");
char mqttnetworkdisconnect = Serial2.read();
Serial.print(mqttnetworkdisconnect);
delay(5000);
//close SSL connection
Serial2.write("AT+QSSLCLOSE=1,10?\r\n");
char closessl = Serial2.read();
Serial.print(closessl);
delay(2000);
//deactivate PDP context
Serial2.write("AT+QIDEACT=1\r\n");
char pdpdisconnect = Serial2.read();
Serial.print(pdpdisconnect);
delay(60000);
delay(100);
