PubSub client retain flag issue to MQQT broker
I just can't seem to find a lot on internet dealing with the issue i have.
So i hope some here can help me out.
When i publish a state command to de MQTT broker i want it to have the flag retain=true.
But i can't seem to get it to work.
Now every time my device (wemos) or mqtt broker (HASSIO) get rebooted the default state gets to "OPEN". and this opens my front door :o
So it is very important to get the retain flag to true from the wemos to HASSIO.
On internet i found that this should work:
client.publish("ha/voordeur/state", "open",true);
But it doesn't. I still get retain=false when using HASSIO-> MQTT developer tab listening tool.
This is my whole sketch:
/////////////////////////////WIFI MANAGER///////////////////////////////////////////////////////
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#if defined(ESP8266)
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
#else
#include <WiFi.h>          //https://github.com/esp8266/Arduino
#endif
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#else
#include <WebServer.h>
#endif
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
////////////////////////////////////////////////////////BLINK INTERNAL LED///////////////////////////////
const int INTERNALledPin =  D4;
int ledState = LOW;             // ledState used to set the LED
unsigned long previousMillis = 0;        // will store last time LED was updated
unsigned long interval = 200;           // interval at which to blink (milliseconds)
//////////////////////////////////////////////////////////RESET WIFI BUTTON//////////////////////////////
#define BUTTON_PIN D7 //> button pin on esp8266
int ButtonState;
///////////////////////////////////////////////////////////////DOOR//////////////////////////////
boolean OpenDoorProcedure = false;
////////////////////////////////////////////////////////////MQTT///////////////////////////////////////////
#include <PubSubClient.h>
const char* mqtt_server = "192.168.2.12";
WiFiClient espClient;
PubSubClient client(espClient);
String Door_open;
String strTopic;
String strPayload;
void callback(char* topic, byte* payload, unsigned int length) {
  payload[length] = '\0';
  strTopic = String((char*)topic);
  if (strTopic == "ha/voordeur/set")
    Door_open = String((char*)payload);
    Serial.println(Door_open);
    if (Door_open == "OPEN")
      OpenDoorProcedure = true;
      //client.publish("ha/voordeur/state", "OPEN");
      Serial.println("CLOSE_123");
      //OpenDoorProcedure = false;
long lastReconnectAttempt = 0;
boolean reconnect() {
  if (client.connect("ESP8266_voordeur", "admin", "admin")) {
    // Once connected, publish an announcement...
    Serial.println("MQTT connected");
    //client.publish("ha/voordeur/state", "closed");
    //client.publish("ha/voordeur/set", "CLOSE");
    // ... and resubscribe
    client.subscribe("ha/#");
  return client.connected();
void setup(void) {
  ///////////////////////////////////////PINMODES///////////////////////////////////////
  pinMode(D3, OUTPUT);//Doorlock
  pinMode(INTERNALledPin, OUTPUT);// internal led
  digitalWrite(D3, LOW);
  digitalWrite(INTERNALledPin, LOW);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  //////////////////////////////////////////WiFiManager////////////////////////////////////////////////
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  //////////////////////////////RESET WIFI//////////////////////
  ButtonState = digitalRead(BUTTON_PIN);
  Serial.println(ButtonState);
  if ( ButtonState == LOW ) {
    Serial.print("Reset");
    wifiManager.resetSettings();
    delay(2000);
  //////////////////////////WifiManager part 2////////////////
  if (!wifiManager.autoConnect("AutoConnectAP")) {
    Serial.println("failed to connect, we should reset as see if it connects");
    delay(3000);
    ESP.restart();
    delay(5000);
  Serial.println("connected...yeey :)");
  Serial.println("local ip");
  /////////////////////////////////////////MQTT SETUP/////////////////////////////////
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void loop(void)
  if (!client.connected()) {
    long now = millis();
    if (now - lastReconnectAttempt > 5000) {
      lastReconnectAttempt = now;
      // Attempt to reconnect
      if (reconnect()) {
    // Client connected
    client.loop();
  ///////////////////////////////////////NEXTION////////////////////
  if (isPwdSShow == 1)
    isPwdSShow = 0;
    key_pressed_count = 0;
    delay(3000);
    //digitalWrite(D3, LOW);
  nexLoop(nex_listen_list);
  //interal_led ();
  //resetwifi ();
  OpenDoorProcedureVoid ();
void OpenDoorProcedureVoid () {
  // Serial.println(OpenDoorProcedure);
  if (OpenDoorProcedure == true) {
    Serial.println("de deur aan het openen");
    digitalWrite(D3, HIGH);
    delay (5000);
    Serial.println("de deur aan het sluiten");
    client.publish("ha/voordeur/state", "closed", true);
void interal_led () {
  if (currentMillis - previousMillis > interval) {
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(INTERNALledPin, ledState);
void resetwifi () {
  //Serial.println(ButtonState);
    // Serial.print("Restart WEMOS");
    ESP.restart();
Can you get a topic setup with a retained message without using your Arduino code?
I'm not sure whether a Hassio implementation has a persistent store by default. If you don't have one configured, I'm not surprised that retain flags don't survive a reboot.
Yes i can.In the hassio .yaml code retain is set to true and it does work if i only use hassio. After reboot the correct state is shown. But when i publish a state to hassio it doesn't retain the last state.
thanks for helping!
