Is it possible to have a prefix for a publish topic? For example the client id? Esphome does this by default. Such as: randomclientid/sensor/humidity
Reason for this is if there are multiple devices which all have a unique client id but the same topic of sensor/humidity they will all publish to the same topic.
I plan on deploying multiple Seeed XIAO esp32c3 devices, all with the same code. The code will extract the mac address to create a unique hostid so every single one will be unique. These will be deployed to multiple server rooms across the US for temp/humidity to a single mqtt host.
What I am stuck with is how to concatenate it. I am ignorant on the how. I am admittingly not a programmer. Have just cobbled together code from various places. I have about 30 different things I want to publish(floats, doubles, etc) that already exist in the code so I want to simplify the publish lines as much as possible.
Here is the code that I think would be helpful to look at to start.
#include <PubSubClient.h>
WiFiClient espClient;
PubSubClient client(espClient);
const char* mqtt_username = "mqtt";
const char* mqtt_password = "password";
String temp_str;
String hum_str;
String client_str;
char APssid[25];
char temp[50];
char hum[50];
char clientid[50];
int32_t chipid=ESP.getEfuseMac();
snprintf(APssid,25, "Sensor-%08X",chipid);
const char broker[] = "192.168.80.21";
int port = 1883;
//set interval for sending messages (milliseconds)
const long interval = 2000;
unsigned long prevMills = 0;
void initMQTT()
Serial.println("MQTT Starting...");
client.setServer(broker, 1883);
void mqttreconnect()
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
if (client.connect(APssid))
//if (client.connect(APssid, mqtt_username, mqtt_password))
Serial.println("connected");
Serial.print("failed, rc=");
Serial.println(client.state());
// Wait 5 seconds before retrying
void mqttLoop()
if (!client.connected())
mqttreconnect();
client.loop();
unsigned long mqttMills = millis();
if (mqttMills - prevMills >= interval) {
// save the last time a message was sent
prevMills = mqttMills;
// send message, the Print interface can be used to set the message contents
client_str = String(APssid);
client_str.toCharArray(clientid, client_str.length() + 1);
//Serial.println("Sending MQTT Data");
hum_str = String(Humidity);
hum_str.toCharArray(hum, hum_str.length() + 1);
client.publish(clientid "/sensor/Humidity", hum);
ok, but in the above "dht11" is static. I wouldn't be able to use it unless I gave every single board a static name instead of it being based on the chipid.
Looking for a way to have the same sketch be used on hundreds of devices. Such as:
client.publish(clientID + "/sensor/humidity", hum);
The code that I posted was an example of the use of the strcpy() and strcat() functions. Both will happily accept a variable as their arguments so you can ise APssid as the argument to strcpy() or you could create the full topic name in snprintf()
