PubSubClient - Programmatically set topic/payload string
I'm playing with the PubSubClient library on an ESP8266. So far for every time I publish or subscribe, I'm using hard-coded topic strings. mqttClient.subscribe("test/relay/enable/cmd"); I would like to programmatically set the topic string using two or three other strings but the only way I can figure out is something like the following.
void sendMqttConnectedMsg(){
  msgString.concat(WiFi.SSID());
  msgString.concat("\r\n");
  msgString.concat(WiFi.macAddress().substring(9));
  String runTime = timeToString(millis() / 1000);
  msgString.concat(runTime);
  char msgChar[msgString.length()+1]; // +1 for NUL terminator
  msgString.toCharArray(msgChar, msgString.length()+1); // same as above, add +1
  mqttClient.publish("test/relay/msg", msgChar, 1);
char * timeToString(unsigned long _t){ // t is time in seconds = millis()/1000;
 static char str[15];
 int d = _t / 86400;
 _t = _t % 86400;
 int h = _t / 3600;
 _t = _t % 3600;
 int m = _t / 60;
 int s = _t % 60;
 sprintf(str, "%04d:%02d:%02d:%02d", d, h, m, s);
 return str;
What are some other techniques where I can create a universal function which takes my 2 or 3 strings as parameters and returns/outputs something PubSubClient can use? Most of my reason for wanting to do this so that I can set a couple strings at the beginning of my program to customize it instead of changing all the instances throughout the code.
strcpy() and strcat() with strings are far better than pissing away resources on the String class.
PaulS: strcpy() and strcat() with strings are far better than pissing away resources on the String class.
How would this code look using only strings instead of Strings?
