# pueden ayudarme ?
**URL:** <https://forum.arduino.cc/t/pueden-ayudarme/563040>\
**Category:** Español\
**Created:** [December 19, 2018, 3:25pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040 "2018-12-19T15:25:56Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![tiketi69](https://avatars.discourse-cdn.com/v4/letter/t/2bfe46/32.png) [@tiketi69](https://forum.arduino.cc/u/tiketi69)\
**Post date:** [December 19, 2018, 3:25pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040/1 "2018-12-19T15:25:56Z")
</div>
tengo un problema y no puedo resolverlo
Este es el sketch:
**Leccion 5 Monitor Serial Adafruit**
```cpp
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
byte leds = 0;
 pinMode(latchPin, OUTPUT);
 pinMode(dataPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 updateShiftRegister();
 while (! Serial);
 Serial.println(*Enter LED Number 0 to 7 or 'x' to clear*);        'Enter' was not declared in this scope
}   ERROR
 if (Serial.available())
   char ch = Serial.read();
   if (ch >= '0' && ch <= '7')
     int led = ch - '0';
     bitSet(leds, led);
     Serial.print(*Turned on LED*);
     Serial.println(led);
 if (ch == 'x')
   leds = 0;
   Serial.println(*Cleared*);
void updateShiftRegister()
 digitalWrite(latchPin, LOW);
 shiftOut(dataPin, clockPin, LSBFIRST, leds);
 digitalWrite(latchPin, HIGH);
**ERROR**
```cpp
Arduino:1.8.5 (Windows 7), Tarjeta:"Arduino Leonardo"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\Mantto\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -ide-version=10805 -build-path C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732 -warnings=none -build-cache C:\Users\Mantto\AppData\Local\Temp\arduino_cache_526208 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose H:\ARD\sketchs\lecc5_MonitorSerial\lecc5_MonitorSerial.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\Mantto\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -ide-version=10805 -build-path C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732 -warnings=none -build-cache C:\Users\Mantto\AppData\Local\Temp\arduino_cache_526208 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose H:\ARD\sketchs\lecc5_MonitorSerial\lecc5_MonitorSerial.ino
Using board 'leonardo' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\sketch\lecc5_MonitorSerial.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\sketch\lecc5_MonitorSerial.ino.cpp" -o "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilando programa...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\sketch\lecc5_MonitorSerial.ino.cpp" -o "C:\Users\Mantto\AppData\Local\Temp\arduino_build_870732\sketch\lecc5_MonitorSerial.ino.cpp.o"
H:\ARD\sketchs\lecc5_MonitorSerial\lecc5_MonitorSerial.ino: In function 'void setup()':
lecc5_MonitorSerial:16: error: 'Enter' was not declared in this scope
H:\ARD\sketchs\lecc5_MonitorSerial\lecc5_MonitorSerial.ino: In function 'void loop()':
lecc5_MonitorSerial:29: error: 'Turned' was not declared in this scope
lecc5_MonitorSerial:36: error: 'Cleared' was not declared in this scope
lecc5_MonitorSerial:36: error: expected primary-expression before ')' token
exit status 1
**Author:** ![evanmars](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/evanmars/32/217678_2.png) [@evanmars](https://forum.arduino.cc/u/evanmars)\
**Post date:** [December 19, 2018, 3:27pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040/2 "2018-12-19T15:27:31Z")
</div>
" " not \* \*
**Post date:** [December 19, 2018, 3:32pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040/3 "2018-12-19T15:32:19Z")
</div>
gracias lo voy a probar
**Author:** ![Surbyte](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/surbyte/32/217404_2.png) [@Surbyte](https://forum.arduino.cc/u/Surbyte)\
**Post date:** [December 19, 2018, 10:03pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040/4 "2018-12-19T22:03:45Z")
</div>
Primero intenta ir a
Ve a Documentación =\> Indice de temas tutoriales =\> Clases de Youtube
Presta atención e intenta entender como funciona este mundo de arduino. Como se programa y como resolver errores.
Los códigos de error que te figuran te dan toda la información
Tu has copiado un código correspondiente a la lección 5 y lo compiaste mal.
Todos tus errores son de tipeo en general.
Ejemplo: primer error
```cpp
Lo primero que dice es
lecc5\_MonitorSerial:29: error: 'Turned' was not declared in this scope
29 es la linea
Lo que quiere decir que el sistema interpreta que Turnes es una variable no declarada pero... si miras bien esta dentro de un Serial.print()
Y todo lo que va dentro de un Serial.print debe ir entre " "
Asi que lo correcto es
```cpp
Serial.print("Turned on LED");
Lo mismo con el siguiente error
```cpp
debe ser
```cpp
Serial.println("Cleared");
**Post date:** [May 6, 2021, 2:13pm UTC](https://forum.arduino.cc/t/pueden-ayudarme/563040/5 "2021-05-06T14:13:27Z")
</div>
