Pull int out of HTTP Response
Thanks for the help in advance. I am currently writing a program that receives an http response and I need to pull one specific integer out of it. The http response currently comes through as a char. I have used sscanf for something like this before, but I can't figure out how to use it here. I am trying to pull the value after Current Value.
This is an example of the response:
HTTP/1.1 200 OK
Date: Wed, 18 Dec 2013 04:28:20 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 177
Connection: close
X-Request-Id: XXXXXXXXXX
Cache-Control: max-age=86400
X-Licence: http://creativecommons.org/publicdomain/zero/1.0/
Vary: Accept-Encoding
{"id":"RequestedTemp","current_value":"150","at":"2013-12-15T03:23:09.472765Z","max_value":"225.0","min_value":"150.0","unit":{"symbol":"F","label":"degrees"},"version":"1.0.0"}
No, it does not. A collection of characters, perhaps. In which case, collecting them in an array is a worthwhile thing to do.
You could use strtok() and atoi() after you have collected the data in a NULL terminated char array. When the token is "current_value", the next token of interest (not necessarily the next token) is the temperature token, which you can pass to atoi().
There is an application called textfinder (below) that captures text out of a text stream. there have been previous post of "weather" code that captures data from returned data from weather sites. You can do simple things like count the " in the returned string and capture the characters after the appropriate number have been counted.
http://playground.arduino.cc/Code/TextFinder
I attempted to use textFinder in the code below, but get the error "no matching function for call to "Textfinder::TextFinder(Adafruit_CC3000_Client&)
  This is a sketch to use the CC3000 WiFi chip & Xively
  Written by Marco Schwartz for Open Home Automation
// Libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include<stdlib.h>
#include <PID_V1.h>
#include <TextFinder.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Define Thermo Pins
#define Thermistor1PIN 1                  // Cabinet Thermistor
#define Thermistor2PIN 2                  // Meat Thermistor 1
#define Thermistor3PIN 3                  // Meat Thermistor 2
#define Thermistor4PIN 4                  // Meat Thermistor 3
//Define Pin for the Relay
#define RelayPin 6
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIV2); // you can change this clock speed
// WLAN parameters
#define WLAN_SSID       "XXXXXXX"
#define WLAN_PASS       "XXXXXXX"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
// Xively parameters
#define WEBSITE  "XXXXXXX"
#define API_key  "XXXXXXX"
#define feedID  "XXXXXXX"
//////Thermometer Function
uint32_t ip;
void setup(void)
  // Initialize
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
void loop(void)
  // Connect to WiFi network
  cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100);
  // Get the website IP & print it
  ip = 0;
  Serial.print(WEBSITE); Serial.print(F(" -> "));
  while (ip == 0) {
    if (! cc3000.getHostByName(WEBSITE, &ip)) {
      Serial.println(F("Couldn't resolve!"));
  cc3000.printIPdotsRev(ip);
  senddata();
  delay (10000);
  getdata();
  cc3000.disconnect();
  // Wait 10 seconds until next update
  delay(50000);
/////sending additional request
  char getdata(){
  Adafruit_CC3000_Client clientb = cc3000.connectTCP(ip, 80);
    clientb.println("GET /v2/feeds/" + String(feedID) + "/datastreams/RequestedTemp.json HTTP/1.0");
    clientb.println("Host: api.xively.com");
    clientb.println("X-ApiKey: " + String(API_key));
    clientb.print("Connection: close");
    clientb.println();
    clientb.println();
  Serial.println(F("-------------------------------------"));
  while (clientb.connected()) {
    while (clientb.available()) {
      char d = clientb.read();
      TextFinder finder(clientb);
      finder.find("current_value");
      long value = finder.getValue();
      Serial.print(value);
  clientb.close();
  void senddata(){
  // Get data & transform to integers
  int temp1=Thermistor(analogRead(Thermistor1PIN));
  int temp2=Thermistor(analogRead(Thermistor2PIN));
  int temp3=Thermistor(analogRead(Thermistor3PIN));
  int temp4=Thermistor(analogRead(Thermistor4PIN));
  // Prepare JSON for Xively & get length
  int messagelength = 0;
  String message2;
  message2 = messages(temp1, temp2, temp3);
  Serial.print("priting message");
  Serial.print (message2);
  messagelength = message2.length();
  Serial.print("Data length");
  Serial.println(messagelength);
  // Send request
    Serial.println("Connected!");
    clientb.println("PUT /v2/feeds/" + String(feedID) + ".json HTTP/1.0");
    clientb.println("Content-Length: " + String(messagelength));
    clientb.println();
    clientb.println(message2);
    clientb.println();
      char c = clientb.read();
      Serial.print(c);
  clientb.close();
//////Functions//////
float vcc = 4.91;                       // only used for display purposes, if used
                                        // set to the measured Vcc.
float pad = 109800;                     // balance/pad resistor value, set this to
                                        // the measured resistance of your pad resistor
float thermr = 222000;                   // thermistor nominal resistance
float Thermistor(int RawADC) {
  long Resistance;
  float Temp;  // Dual-Purpose variable to save space.
  Resistance=((1024 * pad / RawADC) - pad);
  Temp = log(Resistance); // Saving the Log(resistance) so not to calculate  it 4 times later
  Temp = 1 / (-0.000631535825 + (0.0003824312118 * Temp) + (-0.0000003752313105 * Temp * Temp * Temp));
  Temp = Temp - 273.15;  // Convert Kelvin to Celsius
  // Uncomment this line for the function to return Fahrenheit instead.
  Temp = (Temp * 9.0)/ 5.0 + 32.0;                  // Convert to Fahrenheit
  return Temp;                                      // Return the Temperature
/////////Data Function
String messages(int temp1, int temp2, int temp3){
  String message2;
  String message = "";
  message2 = message + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ {\"id\" : \"CabinetTemp\",\"current_value\" : \"" + String(temp1) + "\"}," + "{\"id\" : \"Thermo1\",\"current_value\" : \"" + String(temp2) + "\"}," + "{\"id\" : \"Thermo2\",\"current_value\" : \"" + String(temp3) + "\"}]}";
  return message2;
Did you add the textfinder library to your arduino libraries folder and restart the arduino IDE?
Yes I did, it appears the stream is different for the CC3000 client.
I'm attempting PaulS suggestions now.
I attempted, but all this will return is count = infinite zeros
      char* getstring;
      getstring +=d;
      char *p;
      p = strchr(getstring, 'current value');
      if(p){
        p++;
        int count;
        count = atoi(p);
        Serial.print(count);
You can try counting the " like below if you capture the data string as a String. Try the below with the serial monitor, copy your data string and ctrl-v paste in the serial monitor text box, then send it to the arduino.
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int x=0;
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(2);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    if (c=='"') x=(x+1);
    if (x==7) readString += c;
  if (readString.length() >0) {
    readString = readString.substring(1);
    Serial.print("Your value is: ");
    Serial.println(readString);
    readString="";
    x=0;
      char* getstring;
      getstring +=d;
The pointer, getstring, doesn't point to any memory. You can't add to a string using pointer value manipulation.
      char *p;
Even if that had worked, the second argument to this function call is a single character. Which ONE key did you press to make that single character appear?
The first argument is a garbage pointer that you think points to one character. It is NOT a string (a NULL terminated array of chars), which is what strchr() expects.
You REALLY need to get a C book, and understand pointers, arrays, strings, etc. BEFORE you resort to the String crutch that zoomkat advocates like everyone was a cripple.
Paul S, I completely understand your point and am trying to learn the information as much as possible. As an engineer I prefer to figure out the way things work instead of using band aids to solve problems. I've already invested in a couple books and have started to work through them.
zoomkat, that section of code worked perfectly. Thank you for your help.
PaulS:
…like everyone was a cripple.
That appears to be your thoughts, not mine. Merry Christmas!
zoomkat:
PaulS:
...like everyone was a cripple.
Thank you, and a Merry Christmas to you, too.
