Pull up and pull down resistors
LarryD,
I too am relatively new to programing the Arduino. I have a question about the pulldown resistor in this circuit. I work on equipment that is ground switched and the low condition is almost always 0.7VDC, never 0 volts. Is the pulldown resistor in this circuit there to reduce the input pin to 0? I built this circuit and measured ~1.9VDC at PWM pin 2 and 3 when the resistor is not in the circuit. I do not understand why the PWM input pin has a voltage, is that a design feature of the Arduino?
Thank you for any insight you may have, Hunter
A switch can be wired in one of two different ways.
  1. The switch can be between the pin and GND with a pull up resistor to 5v.
OR
  1. The switch can be between the pin and 5V with a pull down resistor to GND.
Sounds like you are talking about the first.
When you are talking about a PWM pin, it sounds like you are referring to an output, not an input.
A PWM output pin actually has a rectangular wave on it, it outputs pulses of voltage.
PWM
A voltmeter will measure the average voltage of these pulses.
For a 5v Arduino, for a logic 0 (LOW), voltages less than 1.5v are LOW,
VIL.
For a 5v Arduino, for a logic 1 (HIGH), voltages greater than 3v are HIGH,
VIH.
LarryD,
That's a lot of great info! Thanks!!
@idontwantapickle,
Topic split from another topic. Please do not add your own questions to the end of other people's topics.
Could you take a few moments to Learn How To Use The Forum
Thank you.
