Pull-up resistors and sketch upload
Hello all, I don't really have a problem, as I've resolved it already, but I do have a question.
When working with my keypad, I used whatever resistors happened to be laying around my bench (yeah, bad practice, I know =) for the pull-up resistors. They ranged from ~ 260 to ~1M in impedance. The keypad worked great with this setup (well, seemed to at least - I had an issue with the zero key not working =) but I couldn't upload any further sketches until all the pull-up resistors were removed (I got the 'out of sync' error that everyone else has been talking about). After some experimentation, I found that using any pull-up resistor (pulling up a pin to the 5v output on the arduino) rated less than 100KOhm caused the problem. Well, I didn't try, say, 90KOhm! ;D
Obviously, I replaced them all w/ 100K resistors and everything works fine, but why would this cause a problem? (Incidentally, doing this also caused my zero key to function again, heh.)
BTW, they were all connected to the analog inputs (as digital) and digital input 0.
TIA,
!c
There ya go - Digital pins 0 and 1 are used for serial TX and RX (or is that RX and TX?). A low value resistor placed there would screw up rs232 communications used for uploading.
Pins 0 and 1 can be used, but you need to be careful if you want to use them without interering with rs232 communictions, either sketch serial I/O or sketch uploads.
-j
-j
Ahh, excellent - thank you for the explanation. I presume b/c of the matrix nature of the keypad, and I had any row connected to a low-resistance pull-up, and a column connected to pin 0, it would have the same effect (which would seem like it kept happening no matter which pins I removed the pull-up from, pin 0 was connected to COL1).
Hmm. Between 4bit lcd, 4x3 keypad, and 4 motors, those pins start getting more and more scarce =)
!c
