Not sure if this is the right subheader to post this under, but here goes.
I'm using an I2C multiplexer with the Adafruit Flora to send signals to 7 haptic motors. Everything works fine when it's first uploaded and when the serial monitor is open. However, after opening the serial monitor, if I close the monitor the I2C signal is highly delayed and my motor actuation timing is completely off.
I noticed on the COM port that the DTR signal is not being pulled back down to low after the monitor is closed, and was wondering if there's a hardware or software fix for this. The Flora doesn't have a reset pin for me to connect with a resistor, just the reset button, which I imagine would be a pain to solder off. Is the SPI reset pin on the Flora also a reset pin for the board? That would be much easier to access. In terms of software, is there a way to change the port configuration such that the DTR gets pulled back down automatically, say with python?
