Pulling eBay watched item ending notifications
I'm trying to figure out how to use my Yun to pull "watched item ending" and "outbid" notifications to push to a wearable that vibrates to let someone know when those things are happening without having to look at their computer/phone.
Is this possible? Has anyone tried something like this? Any tips?
Another idea I had was since eBay sends me emails with these notifications, maybe finding a way for the Yun to pull an email tagged with the phrase "watched item ending" or "outbid" that would trigger a servo. Could this be accomplished in Temboo?
It is not pull but push, push by Ebay while event take place.
Yun side:
nano /www/ebay.php
<?php
require ("bridgeclient.class.php");
$client = new bridgeclient();
$client->put("D13","On");
echo "OK";
Arduino Side:
#include <Bridge.h>
   	Bridge.begin();
	char lbuffer[256];
	Bridge.get("D13", lbuffer, 256);
access http://.../ebay.php will trigger D13
...” is your public ip address of Yun
Ebay Side:
Subscribing to Platform Notifications with http://.../ebay.php
OutBid Notification Ebay API call “http://.../ebay.php” for the notification to be sent via API (“Platform”)
http://developer.ebay.com/Devzone/guides/ebayfeatures/Notifications/Notifications.html
B.T.W. Yun might not be good candidate for wearable device.
I got the “GetItemStatus” choreo from Temboo to successfully print the specific item’s data in the serial monitor. Now I’m trying to figure out how to take the “EndTime,” subtract 5 minutes from that, and have that time trigger a servo.
Here’s the working Yun code. I’m omitting the AppID since I’m not sure if that’s a confidential number or not…haha.
#include <Bridge.h>
#include <Temboo.h>
#include “TembooAccount.h” // contains Temboo account information, as described below
int numRuns = 1; // Execution count, so this doesn’t run forever
int maxRuns = 10; // Maximum number of times the Choreo should be executed
// For debugging, wait until the serial console is connected.
delay(4000);
while(!Serial);
Bridge.begin();
if (numRuns <= maxRuns) {
Serial.println(“Running GetItemStatus - Run #” + String(numRuns++));
TembooChoreo GetItemStatusChoreo;
// Invoke the Temboo client
GetItemStatusChoreo.begin();
// Set Temboo account credentials
GetItemStatusChoreo.setAccountName(TEMBOO_ACCOUNT);
GetItemStatusChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
GetItemStatusChoreo.setAppKey(TEMBOO_APP_KEY);
// Set Choreo inputs
GetItemStatusChoreo.addInput(“ItemID”, “281510425120”);
GetItemStatusChoreo.addInput(“AppID”, “VCUBrand-0111-4fc7-8764-xxxxxxxxxxx”); //I replaced the AppID with x’s
// Identify the Choreo to run
GetItemStatusChoreo.setChoreo("/Library/eBay/Shopping/GetItemStatus");
// Run the Choreo; when results are available, print them to serial
GetItemStatusChoreo.run();
while(GetItemStatusChoreo.available()) {
char c = GetItemStatusChoreo.read();
Serial.print(c);
GetItemStatusChoreo.close();
Serial.println(“Waiting…”);
delay(30000); // wait 30 seconds between GetItemStatus calls
An example of what is printed in the serial monitor is this (note: this is not what is printed in mine, this is the example I pulled from Temboo):
@xmlns”: “urn:ebay:apis:eBLBaseComponents”,
“Timestamp”: “2013-08-29T20:32:43.596Z”,
“Ack”: “Success”,
“Build”: “E835_CORE_APILW_16258427_R1”,
“Version”: “835”,
“Item”: {
“ItemID”: “110121903191”,
“EndTime”: “2013-08-27T19:58:01.000Z”,
“BidCount”: “1”,
“ConvertedCurrentPrice”: {
@currencyID”: “USD”,
#text”: “20.0”
“HighBidder”: {
“UserID”: “s***_”
“ListingStatus”: “Completed”,
“TimeLeft”: “PT0S”
I want to take the "“2013-08-27T19:58:01.000Z” subtract 5 minutes from that, so “2013-08-27T19:53:01.000Z” and have a servo trigger at that time. Is that even possible?
@sonnyyu
This is probably what I need for my somewhat similar project. Thanks!
Your example seems to differ from the one at http://arduino.cc/en/Tutorial/Bridge on the Arduino side.
Can you explain when to use which approach?
badluckbritt: I want to take the ""2013-08-27T19:58:01.000Z" subtract 5 minutes from that, so "2013-08-27T19:53:01.000Z" and have a servo trigger at that time. Is that even possible?
You have to parse the text to extract the string you want. Then you can convert the string into a number and do the math you need on it.
Here is an example where the output string is processed to extract data http://arduino.cc/en/Tutorial/TimeCheck
@SomethingClever
This is sample for put an php page into web server ( uhttpd) which is Endpoint URL for Ebay Platform Notifications call back.
@badluckbritt
Your code use temboo API.
Monthly call#=2*60*24*30=86,400
https://www.temboo.com/pricing
The temboo monthly cost $49 per product, if You need monitor multiple products then bill will be rocket-up.
Your code also use Ebay API.
Ebay API has Call limit: 5000 per day.
Daily call#=2*60*24=2,880
if you can not monitor more than 1 product.
How ever Platform Notifications API:No limit
http://go.developer.ebay.com/developers/ebay/ebay-api-call-limits
