(Post was too long)
Project Code
#include <Wire.h> // enable I2C.
#include <LiquidCrystal_I2C.h> // Library for LCD
//LiquidCrystal_I2C lcd(0x27, 20, 4);
char sensordata[30];
// A 30 byte character array to hold incoming data from the sensors
byte sensor_bytes_received = 0; // We need to know how many characters bytes have been received
byte code = 0; // used to hold the I2C response code.
byte in_char = 0; // used as a 1 byte buffer to store in bound bytes from the I2C Circuit.
#define TOTAL_CIRCUITS 4 // <-- CHANGE THIS | set how many I2C circuits are attached to the Tentacle shield(s): 1-8
int channel_ids[] = {97, 98, 99, 102};// <-- CHANGE THIS.
// A list of I2C ids that you set your circuits to.
// This array should have 1-8 elements (1-8 circuits connected)
char *channel_names[] = {"DO", "ORP", "PH", "RTD"}; // <-- CHANGE THIS.
// A list of channel names (must be the same order as in channel_ids[])
// it's used to give a name to each sensor ID. This array should have 1-8 elements (1-8 circuits connected).
// {"PH Tank 1", "PH Tank 2", "EC Tank 1", "EC Tank2"}, or {"PH"}
int DO;
double ORP;
double PH;
double RTD;
int z;
String SDO;
String SORP;
String StrPH;
String STemp;
String Content;
float data[] = {1,2,3,4};
int var;
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "192.168.1.171"; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 60000; // delay between updates, in milliseconds
#if defined (ARDUINO_SAM_DUE) // On Arduino Due the standard I2C pins are Wire1, not Wire.
#define WIRE Wire1
#else
#define WIRE Wire
#endif
#if defined (ARDUINO_SAM_DUE) || defined (ARDUINO_SAMD_ZERO)
#define I2C_ONLY 1
#endif
#if !defined(I2C_ONLY)
#include <SoftwareSerial.h> //Include the software serial library
SoftwareSerial sSerial(11, 10); // RX, TX - Name the software serial library sSerial (this cannot be omitted)
// assigned to pins 10 and 11 for maximum compatibility
SoftwareSerial Bluetooth(3, 2);
const int s0 = 7; //Arduino pin 7 to control pin S0
const int s1 = 6; //Arduino pin 6 to control pin S1
const int enable_1 = 5; //Arduino pin 5 to control pin E on shield 1
const int enable_2 = 4; //Arduino pin 4 to control pin E on shield 2
#endif
//Cal stuff
byte computer_bytes_received = 0; //We need to know how many characters bytes have been received
int channel; //INT pointer for channel switching - 0-7 serial, 8-127 I2C addresses
char *cmd; //Char pointer used in string parsing
int retries; // com-check functions store number of retries here
boolean answerReceived; // com-functions store here if a connection-attempt was successful
byte error; // error-byte to store result of Wire.transmissionEnd()
String stamp_type; // hold the name / type of the stamp
char stamp_version[4]; // hold the version of the stamp
char computerdata[20]; //we make a 20 byte character array to hold incoming data from a pc/mac/other.
int computer_in_byte;
boolean computer_msg_complete = false;
byte i2c_response_code = 0; //used to hold the I2C response code.
#if !defined (I2C_ONLY)
const long validBaudrates[] = { // list of baudrates to try when connecting to a stamp (they're ordered by probability to speed up things a bit)
38400, 19200, 9600, 115200, 57600
long channelBaudrate[] = { // store for the determined baudrates for every stamp
0, 0, 0, 0, 0, 0, 0, 0
#endif
boolean I2C_mode = false; //bool switch for serial/I2C
int option;
void(* resetFunc) (void) = 0;//declare reset function at address 0
//Cal stuff end
//SCREEN
#include <hd44780.h>
#undef hd44780_h // undefine this so the example sketch does not think hd44780 is being used.
// cols and rows don't have to be exact to still get accurate transfer numbers
#define LCD_COLS 20
#define LCD_ROWS 4
// declare the lcd object
// Note: The i2c address and pin mappings must match the backpack
const uint8_t i2cAddr = 0x27;
const int rs=0, rw=1, en=2, db4=4, db5=5, db6=6, db7=7, bl=3, blpol=POSITIVE;
LiquidCrystal_I2C lcd(i2cAddr, en, rw, rs, db4, db5, db6, db7, bl, blpol);
#define HD44780_LCDOBJECT
void setup() { // startup function
Serial.begin(9600); // Set the hardware serial port.
Bluetooth.begin(9600);
Wire.begin(); // enable I2C port.
//Initialize serial and wait for port to open:
lcd.begin(20,4);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
createConnection();
//Cal Stuff
pinMode(s1, OUTPUT); //Set the digital pin as output.
pinMode(s0, OUTPUT); //Set the digital pin as output.
pinMode(enable_1, OUTPUT); //Set the digital pin as output.
pinMode(enable_2, OUTPUT); //Set the digital pin as output.
#endif
while (!Serial) ; // Leonardo-type arduinos need this to be able to write to the serial port in setup()
sSerial.begin(38400); // Set the soft serial port to 38400
#endif
WIRE.begin(); // enable I2C port.
stamp_type.reserve(16); // reserve string buffer to save some SRAM
Bluetooth.println("Press 1 for Calibration");
delay(5000);
option = Bluetooth.read();
lcd.clear();
lcd.print(option);
Bluetooth.print(option);
if(option == 49){
intro(); // display startup message
//Cal stuff end
if(option == 49){
calibration();
else {
dataLogging();
Bluetooth Barebones Code
int option;
delay(2000);
delay(5000);
Serial.print(option);
m_c.ino (39 KB)
