pullup resistors for PCF8574_P IC's
I'm using two I2C chips PCF8574_P to read two matrix keypads. I know that I connect Arduino A4 to the SDA pin of the IC and Arduino A5 to the SCL of the IC. Then connect the second IC to the same SDA and SCL wires in series. My question is where to put the 10K pullup resitors to Vcc. Do I put two pullup resistors between the ATmega IC and the PCF8574_P, connected to both the SDA and Vcc & SCL and Vcc, plus a second set of pullup resistors between the two PCF8574_P's connected in the same way, OR do I only require two pullup resistors between the two PCF8574_P IC's?
Yes, I do know that I need difference addresses for each I2C IC.
You only need one set of resistors. And if you bought the PCF8574 as a module (from China or something) chances are there is already a pull up present.
No, I didn't buy a module. I have the chips and I'm creating my own PCB, working it all out on a few breadboards at the moment before I commit to a PCB. So, I only need a single set of pullup resistors, do I put them between the ATmega IC and the first PCF8574 or between the two PCF8574 ICs?
Where to place them doesn't really matter when they're all nice on the same PCB. But usually it's near the master.
