Pulse counter with ethernet
I just discovered Arduino so I'm looking for some advice for the following project that want to realise. I want to read the pulses of 3 electric power meters ( 1000puls/kWh ) and count them separately during 24 hours. Then stock those values temporary with a date and time stamp. Those values I want to read in to my PC with ethernet. There I want to do some calculations and then give back an order to set or reset a switch. Can you give some advice if the Arduino Ethernet Board is the correct one and for clock the RTC1307? Thanks in advance
Yes, it is.
It's a good choice. Not terribly accurate, but not too bad.
Thanks for the advice.
