Hello, i'm rather new to the PLC/controller world and very much like to learn about it more. I was tasked with a project - find a pressure drop of a product. I have 2 K-type thermocouples, 2 pressure transducers (4-20ma), and a solenoid (analog output).
Keeping all that in mind i need to read pulses or frequency from a flow meter. Currently I have it adjusted to 0.1 Lb/min per pulse with a pulse width of 150ms. I've written the following code to test sensors and it does not get anywhere near what the actual value is (20 Lb/min) and it doesn't seem to be stable either. I've tried using the interrupt method found on this forum with no luck either.
#include <Arduino_MachineControl.h>
#include <USBHost.h>
#include "Wire.h"
#include "USBconn.h"
using namespace machinecontrol;
uint16_t readings = 0; //for digital input
volatile unsigned long pulseCount = 0; // pulse count
unsigned long lastPulseTime = 0; //time of the last pulse
unsigned long currentPulseTime = 0;
//4-20mA Input Setup
#define SENSE_RES 120
float reference = 3.3;
//Flow Rates and Factor
float flowrate = 0.00;
//Temperature Variables
float Tin = 0.00; //Ch0
float Tout = 0.00; //Ch1
Wire.begin();
Wire.setClock(1000000);
//Enabling Thermocouples
temp_probes.tc.begin();
Serial.println("Temperature probes initialization done");
temp_probes.enableTC();
Serial.println("Thermocouples enabled");
//Enabling Pressure Sensors
analogReadResolution(16);
analog_in.set4_20mA();
//Valve Signal Output - 0-10V ANALOG OUTPUT open
analog_out.period_ms(0, 10.4);
//Check Flow Meter Digital Input and Setup
if (!digital_inputs.init())
Serial.println("Digital input GPIO expander initialization fail!!");
//Printing Values from all sensors Continuously
//Temp in F
temp_probes.selectChannel(0);
Tin = temp_probes.tc.readTemperature()*1.8+32;
Serial.print("Tin:");
Serial.print(Tin);
temp_probes.selectChannel(1);
Tout = temp_probes.tc.readTemperature()*1.8+32;
Serial.print("Tout:");
Serial.print(Tout);
delay(50);
//Pressure
float raw_voltage_ch0 = analog_in.read(0);
float voltage_ch0 = (raw_voltage_ch0 * reference) / 65535;
float current0 = (voltage_ch0 / SENSE_RES) * 1000;
float Pin = (current0-4)*100/16;
Serial.print("Pin:");
Serial.print(Pin);
float raw_voltage_ch1 = analog_in.read(1);
float voltage_ch1 = (raw_voltage_ch1 * reference) / 65535;
float current1 = (voltage_ch1 / SENSE_RES) * 1000;
float Pout = (current1-4)*100/16;
float dP = Pout-Pin;
Serial.print("Pout:");
Serial.print(Pout);
Serial.print("dP:");
Serial.println(dP);
delay(50);
//Flow Meter
readings = digital_inputs.read(DIN_READ_CH_PIN_00);
if (readings = 1)
pulseCount++;
currentPulseTime = millis();
if (pulseCount > 0 && currentPulseTime - lastPulseTime >= 1000)
flowrate = (pulseCount * 0.1) / ((currentPulseTime - lastPulseTime) / 60000.0);
Serial.print("flowrate:");
Serial.print(flowrate);
pulseCount = 0;
lastPulseTime = currentPulseTime;
delay(20);
