Pulse generation using atmega 328 on arduino uno board.
I am trying to generate 6 firing pulses for firing SCR in AC to DC conversion. Following is the code used for the purpose.
As soon as the interrupt is set, pins 13 and 5 go HIGH and then LOW, continuously for a period of 5ms giving a train of pulses.After 5ms they completely go LOW Thereafter exactly after 10ms from the point when the above two pins started to give pulses, pins 6 and 7 generate train of pulses for 5 min and for next 5 mins they are completely OFF.
But as soon as I start execution after the interrupt is generated, pulses are obtained from the 13 and 6 pins. but after a delay its been observed we are receiving the pulses for some time , but then there occurs a patch of time(almost 2 seconds) where none of these pulses are obtained from the micro controller.
int pin = 13;
volatile int state = 0;
int i;
pinMode(pin, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
attachInterrupt(0, Comparator, RISING);
if(state==1){
for(i=0; i<=2 ; i++){
digitalWrite(pin, HIGH);
digitalWrite(5, HIGH);
delayMicroseconds(1000);
digitalWrite(pin, LOW);
digitalWrite(5, LOW);
delayMicroseconds(4114);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
delayMicroseconds(3668);
void Comparator(){
state=1;
detachInterrupt(0);
Don’t forget to add code tags by selecting your code an clicking on the ‘#’ icon above the text box.
Of course your blinking repeats… Nothing turns off “state=1” so every time through loop() it repeats the pattern.
const int pin = 13;
int i;
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  if(state==1) {
    for(i=0; i<=2 ; i++) {
void Comparator() {
  state=1;
  detachInterrupt(0);
