Pulse Out library
this is my first one,
I've learned a lot with this forum and I would like to contribute with a library that I've made to pulse a pin.
It has some functions to pulse a pin in different ways.
PulseH(long); //H -> t -> L
PulseL(long); //L -> t -> H
PulseHVar(long, long); //H -> t1 -> L -> t2
PulseLVar(long, long); //L -> t1 -> H -> t2
PulseTrain(long, long); //H -> t -> L -> t -> H for n times
PulseTrainVar(long, long, long); //H -> t1 -> L -> t2 -> H for n times
hey!, everything stated with the Blink project.
I hope you enjoy and thanks for all.
PulsePlus.7z (1.33 KB)
thanks for sharing, a good start
a few comments:
pulseplus.h.cpp should be named pulseplus.cpp That is the standard naming convention
(pulseOut is imho an even better name)
int pin -> uint8_t pin (using 1 byte instead of 2)
you use delay extensively, but the parameter type of delay is unsigned long,
so you should use unsigned long in your interface. Prevents negative values !!
furthermore you should mention that the code is blocking
missing option to switch between delay() and delaymicros() ?
codesize can be minimized as functions are quite similar e.g.
void PulseOut(uint8_t startMode, unsigned long duration)
  digitalWrite(_pin, startMode);
  delay(duration);
  digitalWrite(_pin, !startMode);  // ! is inverted value
other member functions pop up. how about a
void PulseOutRandom(uint8_t startMode, unsigned long maxDuration)
  uinsigned long duration = random(maxDuration);
  delay(duration);
Did something related - http://forum.arduino.cc/index.php/topic,139407.0.html -
