Pulse Oximeter Breakout Module YS2000
Hi All,
I'd like to interface one of the below modules to an Arduino Mega. I've searched the web, but cannot find a datasheet for it.
However, there is some information provided on the page, but not very much. I see the board has SCLK marked on it, presumably for SPI comms. Also RX-TX for Serial.
My question is a bit vague, but I'm wondering how difficult/easy it might be to figure out how to use SPI or Serial to get the pulse rate BPM, etc into the Arduino given there's no sample code or even a Byte Order or timing diagram etc, usually found in a datasheet, just by trial and error using Arduino's IDE Serial Monitor or something? This is one of the cheapest units I've seen. There's a Nonin OEM board available that has a datasheet ect, but that's about $300 USD.
Any help/pointers appreciated-
Thanks,
Rich.
http://www.ebay.com/itm/YS2000-Digital-LED-Screen-Spo2-Moduel-Pulse-Oximeter-Accessories-/181162063574?pt=LH_DefaultDomain_0&hash=item2a2e19b6d6
I've just bought this spo2 module (ys2000a, with usb) from aliexpress. A manual can be found in berry-med.com web page:
http://www.berry-med.com/UploadFiles/20140820142028862.pdf
It's not very detailed but can help.
I will tell you later on.
