Pulse Sensor add feature
Hello, i would like to attach the pulsesensor code to my menu, this is for a school project, its a gsm that make calls, recive call, send and recive sms and check the pulse of someone person, but i cant add the feature, can anybody help? Here's the code below.
1 - Make call
2 - Answer call
3 - Hang up call
4 - Send message
5 - remake call
6 - check pulse
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8);
char msg;
char call;
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
Serial.println("MENU HELP TECH");
Serial.println("Escolher Opção:");
Serial.println("1 : Fazer chamada");
Serial.println("2 : Atender chamada");
Serial.println("3 : Desligar chamada");
Serial.println("4 : Enviar mensagem");
Serial.println("5 : Retornar chamada");
Serial.println("6 : Verificar Batimentos");
delay(100);
if (Serial.available()>0)
switch(Serial.read())
case '4':
SendMessage();
case '1':
MakeCall();
case '3':
HangupCall();
case '5':
RedialCall();
case '2':
ReceiveCall();
case '6':
pulsacao();
if (mySerial.available()>0)
Serial.write(mySerial.read());
void SendMessage()
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS="+351919849969"\r"); // Replace x with mobile number
mySerial.println("SOS");// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
void ReceiveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
msg=mySerial.read();
Serial.print(msg);
void MakeCall()
mySerial.println("ATD+351919849969;"); // ATDxxxxxxxxxx; -- watch out here for semicolon at the end!!
Serial.println("A chamar "); // print response over serial port
void HangupCall()
mySerial.println("ATH");
Serial.println("Desligar chamada");
void ReceiveCall()
mySerial.println("ATA");
call=mySerial.read();
Serial.print(call);
void RedialCall()
mySerial.println("ATDL");
Serial.println("A remarcar");
void pulsacao()
Projeto.ino (2.23 KB)
Why can't you? It is your program.
I would like to get a source working for the sensor in the menu
Do you have a question about the code to do this? If so, post what you have tried and ask specific questions.
doguerino:
I have no idea what that means.
The sensor will work independent of the menu.
