Pulse Sensor Amped Buzzer Code
Hi everybody,
I am trying to make a buzzer go off, as soon as my Pulsesensor Amped does not detect anything I tried to do this by modifying the code and insert a tone and delay input.
This is my code:
/* Pulse Sensor Amped 1.4 by Joel Murphy and Yury Gitman http://www.pulsesensor.com
---------------------- Notes ---------------------- ----------------------
This code:
  1. Blinks an LED to User's Live Heartbeat PIN 13
  2. Fades an LED to User's Live HeartBeat
  3. Determines BPM
  4. Prints All of the Above to Serial
Read Me:
// Variables
int pulsePin = 0; // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13; // pin to blink led at each beat
int fadePin = 5; // pin to do fancy classy fading blink at each beat
int fadeRate = 0; // used to fade LED on with PWM on fadePin
// Volatile Variables, used in the interrupt service routine!
volatile int BPM; // int that holds raw Analog in 0. updated every 2mS
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false; // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
// Regards Serial OutPut -- Set This Up to your needs
static boolean serialVisual = false; // Set to 'false' by Default. Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
void setup(){
pinMode(blinkPin,OUTPUT); // pin that will blink to your heartbeat!
pinMode(fadePin,OUTPUT); // pin that will fade to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
// UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
// Where the Magic Happens
void loop(){
serialOutput() ;
if (QS == true){ // A Heartbeat Was Found
// BPM and IBI have been Determined
// Quantified Self "QS" true when arduino finds a heartbeat
digitalWrite(blinkPin,HIGH); // Blink LED, we got a beat.
fadeRate = 255; // Makes the LED Fade Effect Happen
// Set 'fadeRate' Variable to 255 to fade LED with pulse
serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
QS = false; // reset the Quantified Self flag for next time
else {
tone(8,2000,10);
delay(10);
tone(8,2000,10);
delay(10);
tone(8,2000,10);
delay(10);
ledFadeToBeat(); // Makes the LED Fade Effect Happen
delay(20); // take a break
void ledFadeToBeat(){
fadeRate -= 15; // set LED fade value
fadeRate = constrain(fadeRate,0,255); // keep LED fade value from going into negative numbers!
analogWrite(fadePin,fadeRate); // fade LED
[/color]
I got the error message:
core.a(Tone.cpp.o): In function __vector_7': /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Tone.cpp:535: multiple definition of __vector_7'
PulseSensorAmped_Arduino_1dot4.cpp.o:/Applications/Interrupt.ino:27: first defined here
I would really appreciate if you could help me with this as I am under time pressure and need to finish this for school.
Thank you in advance!
jon
Welcome to the Forum. Please read the two posts
How to use this forum - please read.
and
Read this before posting a programming question ...
at the top of this Forum on guidelines for posting here, especially the use of code tags which make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons.
Many questions can be answered by simply reading the documentation which is provided with the IDE, available under the help tab, or online here.
If you have already posted without using code tags, open your message and select "modify" from the pull down menu labelled, "More", at the lower left corner of the message. Highlight your code by selecting it (it turns blue), and then click on the "</>" icon at the upper left hand corner. Click on the "Save" button.
