Hi, I've got this pulse sensor code below. The problem is that the pulse rate is taken too long to stabilize (like 10-13 seconds). the pulse rates start around 23, then to reach my actual pulse rate of around 70 it takes 10-13 seconds. Why? Anything I can change in the code or library to make things more responsive?
Arduino code below.
#define USE_ARDUINO_INTERRUPTS true
// Include necessary libraries
#include <PulseSensorPlayground.h>
// Constants
const int PULSE_SENSOR_PIN = 0; // Analog PIN where the PulseSensor is connected
const int LED_PIN = 13; // On-board LED PIN
const int THRESHOLD = 550; // Threshold for detecting a heartbeat
// Create PulseSensorPlayground object
PulseSensorPlayground pulseSensor;
// Initialize Serial Monitor
// Configure PulseSensor
pulseSensor.analogInput(PULSE_SENSOR_PIN);
pulseSensor.blinkOnPulse(LED_PIN);
pulseSensor.setThreshold(THRESHOLD);
// Check if PulseSensor is initialized
if (pulseSensor.begin())
Serial.println("PulseSensor object created successfully!");
// Get the current Beats Per Minute (BPM)
int currentBPM = pulseSensor.getBeatsPerMinute();
// Check if a heartbeat is detected
if (pulseSensor.sawStartOfBeat())
Serial.println("♥ A HeartBeat Happened!");
Serial.print("BPM: ");
Serial.println(currentBPM);
// Add a small delay to reduce CPU usage
delay(20);
Library code below
A central Playground object to manage a set of PulseSensors.
See https://www.pulsesensor.com to get started.
Copyright World Famous Electronics LLC - see LICENSE
Contributors:
Joel Murphy, https://pulsesensor.com
Yury Gitman, https://pulsesensor.com
Bradford Needham, @bneedhamia, https://bluepapertech.com
Licensed under the MIT License, a copy of which
should have been included with this software.
This software is not intended for medical use.
NOTE: Every Sketch that uses the PulseSensor Playground
must define the variable USE_ARDUINO_INTERRUPTS *before* including
PulseSensorPlayground.h. If you don't, you will get a compiler error
about "undefined reference to `PulseSensorPlayground::UsingInterrupts".
In particular, if your Sketch wants the Playground to use interrupts
to read and process PulseSensor data, your Sketch must contain the
following two lines, in order:
If, instead, your Sketch does not use interrupts to read PulseSensor
data, your Sketch must instead contain the
#define USE_ARDUINO_INTERRUPTS false
See utility/interrupts.h for details.
Internal, developer note: in the Playground code, don't use
USE_ARDUINO_INTERRUPTS as a variable; instead, refer to
PulseSensorPlayground::UsingInterrupts, which is a static variable
that reflects what the Sketch defined USE_ARDUINO_INTERRUPTS to.
Because USE_ARDUINO_INTERRUPTS is defined *only* in the user's Sketch,
it doesn't exist when the various Playground modules are compiled.
See further notes in interrupts.h
#ifndef PULSE_SENSOR_PLAYGROUND_H
#define PULSE_SENSOR_PLAYGROUND_H
If you wish to perform timing statistics on your non-interrupt Sketch:
Uncomment the line below: #define PULSE_SENSOR_TIMING_ANALYSIS true
Compile and download your Sketch.
Start the Arduino IDE Serial Monitor.
Wait about 30 seconds. The Sketch should then print 3 numbers and hang.
The three numbers are:
Minimum variation (microseconds) from the 2 millisecond sample time.
Average variation in that number.
Maximum variation in that number.
For example and output of -4 0 18 says that samples were made between
4 microseconds short of 2 milliseconds, and 18 microseconds longer,
with an average sample time right at 2 milliseconds (0 microseconds offset).
If the average number is larger than, say, 50 microseconds, your Sketch
is taking too much time per loop(), causing inaccuracies in the
measured signal, heart rate, and inter-beat interval.
You should aim for an average offset of under 50 microseconds.
NOTES:
1) This is an approximate measure, because interrupts can occur that
the timing statistics cannot measure.
2) These statistics compile only for non-interrupt Sketches. If your
Sketch uses Interrupts to sample the PulseSensor signal, enabling
this timing analysis will have no effect and will print nothing.
3) Because timing analysis results are printed on Serial, you cannot
use the Arduino IDE Serial Plotter or the Processing Visualizer to
examine output when timing analysis is enabled.
4) If the average is a negative number, your assumed Arduino clock
speed may be incorrect. For example, if you compiled for an 8MHz clock
and your Arduino actually runs at 16MHz, you would likely see an
average offset of something like -1000.
#define PULSE_SENSOR_TIMING_ANALYSIS false
//#define PULSE_SENSOR_TIMING_ANALYSIS true
If you wish to print the amount of memory used before your Sketch
starts:
Uncomment the line below: #define PULSE_SENSOR_MEMORY_USAGE true
Your Sketch will start normally, then print memory usage, then hang.
The memory usage consists of five numbers:
data = bytes of global, uninitialized data storage (int x;)
bss = bytes of global, initialized data storage (int x = 5;)
heap = bytes of dynamically allocated memory (new Stream;)
stack = bytes of local variables (those defined within a function)
total = the total of data, bss, heap, and stack memory used.
The amount of flash memory used is printed by the Arduino IDE
when compilation finishes, with a printout such as:
Sketch uses 5036 bytes (15%) of program storage space.
NOTE: you must call pulse.setSerial(Serial) in your Sketch's setup().
#define PULSE_SENSOR_MEMORY_USAGE false
//#define PULSE_SENSOR_MEMORY_USAGE true
Tell the compiler not to include Serial related code.
If you are coming up against issues with the Serial class
removing the related code here can help.
When true, the library can mangage Serial output,
and messages from libraries will be printed.
When false, the library will not have any access to the Serial
class. All the other functionality remains.
#define USE_SERIAL true
// #define USE_SERIAL false
#if defined(ARDUINO_ARCH_NRF52)
#include "Adafruit_TinyUSB.h"
#endif
#include <Arduino.h>
#include "utility/PulseSensor.h"
#if USE_SERIAL
#include "utility/PulseSensorSerialOutput.h"
#endif
#include "utility/PulseSensorTimingStatistics.h"
class PulseSensorPlayground {
public:
The number of microseconds per sample of data from the PulseSensor.
1 millisecond is 1,000 microseconds.
Refer to this value as PulseSensorPlayground::MICROS_PER_READ
static const unsigned long MICROS_PER_READ = (2 * 1000L); // usecs per sample.
//---------- PulseSensor Manager functions
Construct the one PulseSensor Playground manager,
that manages the given number of PulseSensors.
Your Sketch should declare either PulseSensorPlayground() for one sensor
or PulseSensorPlayground(n) for n PulseSensors.
For example:
PulseSensorPlayground pulse();
or
PulseSensorPlayground pulse(2); // for 2 PulseSensors.
PulseSensorPlayground(int numberOfSensors = 1);
Start reading and processing data from the PulseSensors.
Your Sketch should make all necessary PulseSensor configuration calls
before calling begin().
If the Sketch defined USE_ARDUINO_INTERRUPTS as true, this function
sets up and turns on interrupts for the PulseSensor.
If instead the Sketch defined USE_ARDUINO_INTERRUPTS as false,
it initializes what's necessary for the Sketch to process
PulsSensor signals. See sawNewSample(), below.
Returns true if successful, false if unsuccessful.
Returns false if PulseSensorPlayground doesn't yet support
interrupts on this Arduino platform and the user's Sketch
did a #define USE_ARDUINO_INTERRUPTS true.
If begin() returns false, you can either use a different
type of Arduino platform, or you can change your Sketch's
definition of USE_ARDUINO_INTERRUPTS to false:
boolean begin();
Returns true if a new sample has been read from each PulseSensor.
You'll likely want to add this call to your Sketch's loop()
only if you either 1) want to do something with each sample of the
PulseSensor signals, or 2) your Sketch doesn't use interrupts
to read from the PulseSensors.
NOTE: If your Sketch defined USE_ARDUINO_INTERRUPTS as false,
you must call pulse.sawNewSample() frequently (at least
once every 2 milliseconds) to assure that PulseSensor signals
are read accurately.
A typical loop() that doesn't use interrupts will contain:
if (pulse.sawNewSample()) {
int latest = pulse.getLatestSample();
...do whatever you want with the sample read from the PulseSensor.
boolean sawNewSample();
//---------- Per-PulseSensor functions
By default, the Playground assumes the PulseSensor is connected to A0.
If your PulseSensor is connected to a different analog input pin,
call pulse.analogInput(pin) or pulse.analogInput(pin, sensorIndex).
inputPin = the analog input this PulseSensor is connected to.
sensorIndex = optional, index (0..numberOfSensors - 1)
of the PulseSensor to configure.
void analogInput(int inputPin, int sensorIndex = 0);
By default, the Playground doesn't blink LEDs automatically.
If you wish the Playground to automatically blink an LED
during each detected pulse,
call pulse.blinkOnPulse(blinkPin) or
pulse.blinkOnPulse(blinkPin, sensorIndex).
blinkPin = the pin to blink on each pulse, which you've connected
to an LED and 220 ohm resistor, or the built in LED pin
on your Arduino (for example, pin 13 on Arduino Uno).
void blinkOnPulse(int blinkPin, int sensorIndex = 0);
If you wish the Playground to automatically blink a fading LED
call fadeOnPulse(fadePin) or fadeOnPulse(fadePin, sensorIndex).
NOTE: the fade pin must be a PWM (Pulse-Width Modulation) pin.
fadePin = the PWM pin to blink and fade on each pulse,
which is connected to an LED and a current-limit resistor.
void fadeOnPulse(int fadePin, int sensorIndex = 0);
(Internal to library - do not call from a Sketch)
Perform all the processing necessary when it's time to
read from all the PulseSensors and process their signals.
void onSampleTime();
Returns the most recently read analog value from the given PulseSensor
(range: 0..1023).
of the PulseSensor of interest.
int getLatestSample(int sensorIndex = 0);
Returns the latest beats-per-minute measure for the given PulseSensor.
The internal beats-per-minute measure is updated per-PulseSensor,
when a beat is detected from that PulseSensor.
int getBeatsPerMinute(int sensorIndex = 0);
Returns the latest IBI (inter-beat interval, in milliseconds) measure
The internal IBI measure is updated per-PulseSensor,
int getInterBeatIntervalMs(int sensorIndex = 0);
Returns true if a new heartbeat (pulse) has been detected
from the given PulseSensor since the last call to sawStartOfBeat()
on this PulseSensor.
Typical use in loop():
if (pulse.sawStartOfBeat()) {
...do what you want to do per-heartbeat.
boolean sawStartOfBeat(int sensorIndex = 0);
Returns true if the given PulseSensor signal is currently
inside a heartbeat. That is, returns true if the signal is above
the automatically-set threshold of a beat, false otherwise.
if (pulse.isInsideBeat()) {
...do what you want while in the beat.
...do what you want while between beats.
boolean isInsideBeat(int sensorIndex = 0);
By default, the threshold value is 530.
threshold is used to find the heartbeat
adjust this value up in the setup function to avoid noise.
void setThreshold(int threshold, int sensorIndex = 0);
//---------- Serial Output functions
#if USE_SERIAL
By default, the Playround doesn't output serial data automatically.
If you want to output serial pulse data, call pulse.setSerial(Serial),
pulse.setSerial(Serial1), or whatever Serial stream you like.
output = the Stream to write data to. Serial, Serial1, Serial2,
etc., and a SoftwareSerial are valid parameters to pass.
void setSerial(Stream &output);
By default, Playground output is in SERIAL_PLOTTER format.
If you want output in a different format, call this function once
sometime before calling pulse.begin().
Remember to call pulse.setSerial() if you want serial output.
outputType = SERIAL_PLOTTER to output to the Arduino Serial Plotter,
PROCESSSING_VISUALIZER to output to the Processing Sketch
that draws the PulseSensor output.
void setOutputType(byte outputType);
Output the current signal information for each PulseSensor,
in the previously-set outputType.
If your Sketch wants to plot samples, it should call this function
every so often.
void outputSample();
Output the current per-beat information for each PulseSensor,
If your Sketch wants to plot beat information, it should call this
function every time a beat is detected.
Typical use:
pulse.outputBeat();
void outputBeat(int sensorIndex = 0);
Serial print data with prefix.
Used exclusively with the Pulse Sensor Processing sketch.
void outputToSerial(char symbol, int data);
#endif
Returns the current amplitude of the pulse waveform.
int getPulseAmplitude(int sensorIndex = 0);
Returns the sample number when the last beat was found. 2mS resolution.
unsigned long getLastBeatTime(int sensorIndex = 0);
// check to see if the library is sampling (on interrupt OR in software)
boolean isPaused();
// option to pause Pulse Sensor sampling in order to do other stuff
// this function will only tell the timer to stop interrupting
// does not return PWM or other fuctionality to effected pins
boolean pause();
// restart sampling the Pulse Sensor after a pause
boolean resume();
// (internal to the library) "this" pointer for the ISR.
static PulseSensorPlayground *OurThis;
private:
Optionally use this (or a different) pin to toggle high while the algorithm is running.
Connect it to an oscilloscope to determine algorithm run time.
// int timingPin = 10;
Configure and enable interrupts to read samples.
Call only if PulseSensorPlayground::UsingInterrupts is true.
This function is defined (vs. declared here) in interrupts.h
// void setupInterrupt();
// boolean disableInterrupt();
// boolean enableInterrupt();
Don't let the library try to print stuff
if the serial is not passed to us
#if USE_SERIAL
#if PULSE_SENSOR_MEMORY_USAGE
Print our RAM usage. See PULSE_SENSOR_MEMORY_USAGE
void printMemoryUsage();
#endif // PULSE_SENSOR_MEMORY_USAGE
#endif
If true, the Sketch wants to use interrupts to read the PulseSensor(s).
This variable is defined (vs. declared here) in interrupts.h
static boolean UsingInterrupts;
boolean Paused;
byte SensorCount; // number of PulseSensors in Sensors[].
PulseSensor *Sensors; // use Sensors[idx] to access a sensor.
volatile unsigned long NextSampleMicros; // Desired time to sample next.
volatile boolean SawNewSample; // "A sample has arrived from the ISR"
#if USE_SERIAL
PulseSensorSerialOutput SerialOutput; // Serial Output manager.
#endif
#if PULSE_SENSOR_TIMING_ANALYSIS // Don't use ram and flash we don't need.
PulseSensorTimingStatistics *pTiming;
#endif // PULSE_SENSOR_TIMING_ANALYSIS
We include interrupts.h here instead of above
because it depends on variables and functions we declare (vs. define)
in PulseSensorPlayground.h.
#include "utility/Interrupts.h"
#endif // PULSE_SENSOR_PLAYGROUND_H
library cPP file
Contributors:
// Define the "this" pointer for the ISR
PulseSensorPlayground *PulseSensorPlayground::OurThis;
PulseSensorPlayground::PulseSensorPlayground(int numberOfSensors) {
// Save a static pointer to our playground so the ISR can read it.
OurThis = this;
// Dynamically create the array to minimize ram usage.
SensorCount = (byte) numberOfSensors;
Sensors = new PulseSensor[SensorCount];
// We want sample timing analysis, so we construct it.
pTiming = new PulseSensorTimingStatistics(MICROS_PER_READ, 500 * 30L);
boolean PulseSensorPlayground::PulseSensorPlayground::begin() {
for (int i = 0; i < SensorCount; ++i) {
Sensors[i].initializeLEDs();
// Note the time, for non-interrupt sampling and for timing statistics.
NextSampleMicros = micros() + MICROS_PER_READ;
SawNewSample = false;
Paused = false;
// Report the RAM usage and hang.
printMemoryUsage();
for (;;);
// Lastly, set up and turn on the interrupts.
if (UsingInterrupts) {
if (!PulseSensorPlaygroundSetupInterrupt()) {
Paused = true;
return false;
// pinMode(timingPin,OUTPUT);
return true;
void PulseSensorPlayground::analogInput(int inputPin, int sensorIndex) {
if (sensorIndex != constrain(sensorIndex, 0, SensorCount)) {
return; // out of range.
Sensors[sensorIndex].analogInput(inputPin);
void PulseSensorPlayground::blinkOnPulse(int blinkPin, int sensorIndex) {
Sensors[sensorIndex].blinkOnPulse(blinkPin);
void PulseSensorPlayground::fadeOnPulse(int fadePin, int sensorIndex) {
Sensors[sensorIndex].fadeOnPulse(fadePin);
boolean PulseSensorPlayground::sawNewSample() {
If using interrupts, this function reads and clears the
'saw a sample' flag that is set by the ISR.
When not using interrupts, this function sees whether it's time
to sample and, if so, reads the sample and processes it.
First, check to see if the sketch has paused the Pulse Sensor sampling
if(!Paused){
// Disable interrupts to avoid a race with the ISR.
// DISABLE_PULSE_SENSOR_INTERRUPTS;
boolean sawOne = SawNewSample;
// ENABLE_PULSE_SENSOR_INTERRUPTS;
return sawOne;
} else { // Time the sample as close as you can when not using interrupts
unsigned long nowMicros = micros();
if ((long) (NextSampleMicros - nowMicros) > 0L) {
return false; // not time yet.
NextSampleMicros = nowMicros + MICROS_PER_READ;
if (pTiming->recordSampleTime() <= 0) {
pTiming->outputStatistics(SerialOutput.getSerial());
for (;;); // Hang because we've disturbed the timing.
// time to call the sample processor
onSampleTime();
return true;
return false;
void PulseSensorPlayground::onSampleTime() {
// Typically called from the ISR at 500Hz
// digitalWrite(timingPin,HIGH); // optionally connect timingPin to oscilloscope to time algorithm run time
Read the voltage from each PulseSensor.
We do this separately from processing the samples
to minimize jitter in acquiring the signal.
Sensors[i].readNextSample();
// Process those samples.
Sensors[i].processLatestSample();
Sensors[i].updateLEDs();
// Set the flag that says we've read a sample since the Sketch checked.
SawNewSample = true;
// digitalWrite(timingPin,LOW); // optionally connect timingPin to oscilloscope to time algorithm run time
int PulseSensorPlayground::getLatestSample(int sensorIndex) {
return -1; // out of range.
return Sensors[sensorIndex].getLatestSample();
int PulseSensorPlayground::getBeatsPerMinute(int sensorIndex) {
return Sensors[sensorIndex].getBeatsPerMinute();
int PulseSensorPlayground::getInterBeatIntervalMs(int sensorIndex) {
return Sensors[sensorIndex].getInterBeatIntervalMs();
boolean PulseSensorPlayground::sawStartOfBeat(int sensorIndex) {
return false; // out of range.
return Sensors[sensorIndex].sawStartOfBeat();
boolean PulseSensorPlayground::isInsideBeat(int sensorIndex) {
return Sensors[sensorIndex].isInsideBeat();
void PulseSensorPlayground::setThreshold(int threshold, int sensorIndex) {
Sensors[sensorIndex].setThreshold(threshold);
#if USE_SERIAL
void PulseSensorPlayground::setSerial(Stream &output) {
SerialOutput.setSerial(output);
void PulseSensorPlayground::setOutputType(byte outputType) {
SerialOutput.setOutputType(outputType);
void PulseSensorPlayground::outputSample() {
SerialOutput.outputSample(Sensors, SensorCount);
void PulseSensorPlayground::outputBeat(int sensorIndex) {
SerialOutput.outputBeat(Sensors, SensorCount, sensorIndex);
void PulseSensorPlayground::outputToSerial(char s, int d) {
SerialOutput.outputToSerial(s,d);
#endif
int PulseSensorPlayground::getPulseAmplitude(int sensorIndex) {
return Sensors[sensorIndex].getPulseAmplitude();
unsigned long PulseSensorPlayground::getLastBeatTime(int sensorIndex) {
return Sensors[sensorIndex].getLastBeatTime();
boolean PulseSensorPlayground::isPaused() {
return Paused;
boolean PulseSensorPlayground::pause() {
boolean result = true;
if (!PulseSensorPlaygroundDisableInterrupt()) {
Paused = false;
result = false;
}else{
// DOING THIS HERE BECAUSE IT COULD GET CHOMPED IF WE DO IN resume() BELOW
for(int i=0; i<SensorCount; i++){
Sensors[i].resetVariables();
Paused = true;
}else{
// do something here?
Paused = true;
return result;
boolean PulseSensorPlayground::resume() {
if (!PulseSensorPlaygroundEnableInterrupt()) {
Paused = true;
result = false;
}else{
Paused = false;
}else{
Paused = false;
return result;
#if USE_SERIAL
void PulseSensorPlayground::printMemoryUsage() {
char stack = 1;
extern char *__data_start;
extern char *__data_end;
extern char *__bss_start;
extern char *__bss_end;
extern char *__heap_start;
extern char *__heap_end;
int data_size = (int)&__data_end - (int)&__data_start;
int bss_size = (int)&__bss_end - (int)&__data_end;
int heap_end = (int)&stack - (int)&__malloc_margin;
int heap_size = heap_end - (int)&__bss_end;
int stack_size = RAMEND - (int)&stack + 1;
int available = (RAMEND - (int)&__data_start + 1);
available -= data_size + bss_size + heap_size + stack_size;
Stream *pOut = SerialOutput.getSerial();
if (pOut) {
pOut->print(F("data "));
pOut->println(data_size);
pOut->print(F("bss "));
pOut->println(bss_size);
pOut->print(F("heap "));
pOut->println(heap_size);
pOut->print(F("stack "));
pOut->println(stack_size);
pOut->print(F("total "));
pOut->println(data_size + bss_size + heap_size + stack_size);
#endif
