hello i have esp32 node mcu, i try to use pulss sensoer to get the BPM i use the play ground examples but only the getting started project is working
how can i chack the BPM?
this is the esp and the BPM code:
--------Use This Sketch To------------------------------------------
Displays user's live and changing BPM, Beats Per Minute, in Arduino's native Serial Monitor.
Print: " A HeartBeat Happened !" when a beat is detected, live.
Learn about using a PulseSensor Library "Object".
Blinks LED on PIN 13 with user's Heartbeat.
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math. #include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; // Determine which Signal to "count as a beat" and which to ignore.
// Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
// Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
Serial.begin(9600); // For Serial Monitor
// Configure the PulseSensor object, by assigning our variables to it.
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
// "myBPM" hold this BPM value now.
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
Serial.println(" A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
Serial.print("BPM: "); // Print phrase "BPM: "
Serial.println(myBPM); // Print the value inside of myBPM.
delay(20); // considered best practice in a simple sketch.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR https://forum.arduino.cc/index.php?topic=712198.0
Then look down to "code problems" about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you post link to spec/data of the sensor?
Can you post a circuit diagram please?
