Hello,
I want to build a SENT frame, for this a pulse width of max. 3µs is needed. Unfortunately, I do not come here under on the required 3µs. I hope you can help me.
int i = 0;
byte bin[88] = {0b0001 << 0b0100, 0b0001 << 0b0100, 0b0001 << 0b0100, 0b0001 << 0b0100, 0b0001 << 0b0100, 0b0001 << 0b0100, 0b0001 << 0b0100, 0b0000, 0b0001 << 0b0100, 0b0000, 0b0001 << 0b0100, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0001, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0001 << 0b0100, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, 0b0000}; // dauer eines Status 4µs
ISR(TIMER1_COMPA_vect)// alle 63µs
//PORTD= bin[i/*TCNT0*/]; // UNO
PORTH = bin[/*i/*/TCNT0]; // MEGA
//i++;
/*if (i >= 87)
i = 0;
ISR(TIMER0_COMPA_vect) // alle 4ms
TCNT0 = 0;
//i=0;
noInterrupts();//stop interrupts
#ifdef SLOW_CLOCK
noInterrupts();
CLKPR = _BV(CLKPCE); // enable change of the clock prescaler
//CLKPR = _BV(CLKPS0); // divide frequency by 2
interrupts();
#endif
//set Timer1 333,5kHz
TCCR1A = _BV(COM1A0) ; //toggle OC1A on compare match
OCR1A = 5; //top value for counter, 7 = 1MHz 23=333,5kHz
TCCR1B = _BV(WGM12) | _BV(CS11); //CTC mode, prescaler clock/1
TCNT1 = 0;
TIMSK1 = bit(OCIE1A); //interrupt on Compare A Match
//TIMER0
TCCR0A = (1 << COM2A0);//_BV(COM0A0) + (1 << WGM01) + (1 << WGM00); //; (1 << COM2A0);
TCCR0B = (1 << CS01);//_BV(WGM02) + _BV(CS01); //(1 << CS01);
OCR0A = 80;
OCR0B = 40;
TCNT0 = 0;
TIMSK0 = bit(OCIE0A);
DDRD = 0b11111111;
DDRB = 0b11111111;
DDRH = 0b11111111;
PORTD = 0b00000000;
DDRD |= (1 << PD3);
interrupts();
