Pulsed Laser Driver Circuit
Hi all,
I don't have much experience with Arduino but wanted to ask for some advice for a side project I'm doing. I currently have a 850nm wavelength laser diode and wanted to know if it was at all possible to create a driver circuit that pulsed my laser for a length of less than 66 nanoseconds with a pulse frequency of 800 Hz or greater. I'm attempting to shine the resulting laser through a piece of plastic/glass and get absorbed by a contained material.
Thanks!
Also, recommendations on which Arduino products would work best for this sort of thing would be greatly appreciated!
How much current does it use? And is the diode designed to be pulsed? i.e., is it a pulsed diode or does it need an external driver?
Part of the problem will be that laser diodes want to be current driven and getting a current source to operate at those speeds will be challenging.
Yikes, the Amazon listing doesn't have that many specifications on it. What type of laser diode specs would you recommend?
Amazon Link
@cedarlakeinstruments has a good point. You will almost certainly need to buy a commercial laser diode driver module to meet those specs.
Also, the low end Arduinos are slow, for example, the Arduino Uno R3 has a machine cycle time of 16.5 ns, which requires programming at the machine code level to generate a 66 ns pulse.
I see, so ditch trying to use an Arduino entirely?
No, just use a fast one.
But the diode in the Amazon linke already has some sort of current limiting built in and is intended for every low power steady state operation, not pulsed.
Mentioned earlier that the Amazon diode I bought didnt come with much info but supposedly 3V and "less than 5mW". Would buying a 12V 1W laser make this much easier for me?
:sweat_smile:Got any suggestions for boards? Not well versed...[Ebay Laser] Would this laser be good?(808nm 500mw/ 850nm 1000mw 1W Near-infrared Laser Diode Module Focusing Head 12V | eBay)
The shortest pulse that can be generated with an UNO R3 is 62.5ns.
void fireLaser() {
  bitSet(PORTD, 2);    // make pin 3 high
  bitClear(PORTD, 2);  // make pin 3 low
In this case, as the PORT registers are placed in the lower portion of the address space, these instructions will be compiled to opcodes that will be executed in 1 clockcycle. You can use micros() or a hardware timer to trigger the calling of this function.
The electronics of the driver is another matter.
Could the same time be reached using an Uno R4 - ABX00087?
Sorry, 62.5 ns per machine cycle on the R3. I was thinking of another CPU.
If you are serious about this project, you need to estimate how much laser power, at what pulse length is required to do what you want. Then buy a laser diode (and driver) that meets or exceeds those specs, from reputable suppliers.
I think with the budget I have now, I'll try a smaller scale demo for a proof of concept. Spec Sheet This diode can supposedly output 2,000mW at 1 microsecond pulses. The supplier seems to be a solid laser cutting company. Should I still consider buying a premanufactured driver or can I now attempt to build one through an Arduino with the lower pulse length requirement?
Yes. They involve technically advanced designs and require decent understanding of electronic principles for operation. The diode should be mounted in a matching, precision machined heat sink assembly.
I'm not a laser expert...
Here is something I found.
Some laser diodes have have a 3rd connection which works as a "sensor" to monitor light output. It's used in a feedback loop so can get maximum output and the laser doesn't burn itself out.
Any laser diode can be pulsed but not all laser drivers can be pulsed. Since they are "constant current", the circuit that tries to maintain that constant current can sometimes "fight against" pulsing.
There is a circuit called a One Shot that could be used to generate the 66nS pulse. Then you could just "hit it" at 800Hz from the Arduino.
If you don't know this, power is calculated as Power = Voltage x Current. So for example, if the laser is rated for 2V, you'd need to set the current for 1 Amp.
And I assume you know that even if the laser has a visible wavelength, you won't be able to see such a short pulse and it may be difficult to "detect". (You may not know if it's working.)
There is one problem with using a 555 timer to produce 66ns pulses: it is not fast enough.
But: what is the reason for the 66ns mentioned in the first post?
Sure you can.
A 2W IR LASER is extremely dangerous so buy a good pair of protective goggles for that wavelength.
I've bought goggles, a laser cutting shield, and am making a chamber to experiment in.
Originally, I wanted a 66ns pulse since it would induce the photoacoustic effect between the 850nm wavelength laser and an experimental material, but I've opted for a higher pulse duration to save on costs.
