i am sure it’s because i am still beginner so i hesitate to ask stupid questions here. But After maybe 5 hours reading and trying. I hope someone can push me in the right direction.
A 22Ohm resistor is connected between D7 and GND. This resistor is glued to a Dallas temperature sensor. So when D7 is HIGH the resistor heats up the temperature sensor till 1 degrees hotter than a second temp-sensor. That all works fine already.
But i need to measure how long the resistor was ON during the heating process. Which always results in 0
Here is my code:
#define MY_DEBUG
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 10
#define TEMPERATURE_PRECISION 10
int ledPin = 7;
unsigned long duration;
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress temp1 = { 0x28, 0xFF, 0xD0, 0xAB, 0x62, 0x16, 0x03, 0x65 };
DeviceAddress temp2 = { 0x28, 0xFF, 0xB0, 0x6C, 0x63, 0x16, 0x03, 0x60 };
void setup(void)
pinMode(ledPin, OUTPUT); // sets the digital pin as output
// start serial port
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// set the resolution to 9 bit
sensors.setResolution(temp1, TEMPERATURE_PRECISION);
sensors.setResolution(temp2, TEMPERATURE_PRECISION);
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
sensors.requestTemperatures();
Serial.println("Requesting temperatures...DONE");
float in = sensors.getTempC(temp1);
Serial.print("In C: ");
Serial.println(in);
float out = sensors.getTempC(temp2);
Serial.print("Out C: ");
Serial.println(out);
duration = pulseIn(ledPin, HIGH);
digitalWrite(ledPin, LOW);
while (in < (out + 1)) {
digitalWrite(ledPin, HIGH);
Serial.println("Heating Up...");
Serial.print(" In Temp: ");
Serial.println(in);
Serial.print("Was HIGH for:");
Serial.println(duration);
Serial.println("Heating OFF");
delay (5000);
Don’t be too hard with me
