pulseIn doesn't work // LEDs dont blink // how can i make sth. wait for sth.?
Hey, in School we got a project to create a gambling game and i had the idea of a program, that starts when the button is first pressed, then you have to hold down the button for 1/2/3/4 seconds to bet on the 1st/2nd/3rd/4th LED then if you swipe over the LDR the game starts and shuffles through the LEDs (they blink like a wheel of fortune) then a random LED blinks and if the BetLED corresponds to the RandomLED you win, else you lose.
My problem is, that the pulseIn doesn't work it always gives me values beneath 1 second and then my program does automatically bet on the first LED. My second problem is that in the Win-for-loop the LEDs don't blink but the Serial Monitor shows me the Text that is in there ''You won!''. And My third Problem is how can i make the 2nd last if loop to wait for the swipe over the LDR?
Thanks for your Help already :slight_smile: ( And sorry, if my english is bad :D)
int ledred = 6;
int ledred1= 7;
int ledred2= 8;
int ledred3= 9;
int Button= 2;
int ButtonCondition=0;
int BetNumber;
unsigned long Duration;
int Light;
int RandomNumber;
  pinMode(ledred,OUTPUT);
  pinMode(ledred1,OUTPUT);
  pinMode(ledred2,OUTPUT);
  pinMode(ledred3,OUTPUT);
  pinMode(Button,INPUT);
  Serial.begin (9600);
  randomSeed(analogRead(0));
  Serial.println(analogRead(0));
  Serial.print("Please press the Button. Depending on which LED you want to bet, hold down the Button for 1/2/3/4 Seconds. ");
  Serial.print("You have to count in your Mind, on which LED you are.");
  ButtonCondition=digitalRead(Button);
  if(ButtonCondition==1)
    Duration = pulseIn(2,HIGH); // doesn't work, return value always is < 1000 even if I press the button for 5 seconds.
    delay(100);
    if(Duration<=1000)
      digitalWrite(ledred,HIGH);
      BetNumber=6;
      Serial.println(" You bet on the first LED.");
      delay(100);
      if(Duration<=2000&&Duration>=1000)
      digitalWrite(ledred1,HIGH);
      BetNumber=7;
      Serial.println(" You bet on the second LED.");
      delay(100);
      if(Duration<=3000&&Duration>=2000)
      digitalWrite(ledred2,HIGH);
      BetNumber=8;
      Serial.println(" You bet on the third LED.");
      delay(100);
      if(Duration<=4000&&Duration>=3000)
      digitalWrite(ledred3,HIGH);
      BetNumber=9;
      Serial.println(" You bet on the fourth LED.");
      delay(100);
    digitalWrite(ledred,LOW);
    digitalWrite(ledred1,LOW);
    digitalWrite(ledred2,LOW);
    digitalWrite(ledred3,LOW);
  Serial.print("To start the gambling game, swipe over the LDR."); // it should wait here, for the user to swipe over it and don't continue after the if loop
  if(Light<=700);
      for(int slower = 0;slower<=200;slower=slower+10)
     delay(slower);
     delay(slower);
     delay(slower);
     delay(slower);
    RandomNumber= random(6,10);
    digitalWrite(RandomNumber,HIGH);
    delay(100);
    digitalWrite(RandomNumber,LOW);
    if(RandomNumber==BetNumber)
      for(int Win=0;Win<=10;Win=Win+1) // the LEDs in this for loop don't even blink, but the serial monitor shows the ''you won!''
        delay(15);
        Serial.print("You won!");
      Serial.print("You lost.");
I know you apologised for your English, but what does that mean, please?
What is "sth"?
AWOL:
What is "sth"?
sry it didnt fit in the subject anymore. I meant something ^^
In the playground look up de-bouncing buttons and double check your use of pulseIn() in fact just drop your use of pluseIn.
Mark
holmes4:
Mark
    Duration = pulseIn(2,HIGH,5000000); // if 5 Seconds long no pulse -> Duration= 0?
    delay(100);
    if(Duration<=1000000) // is this now 1 second and the other 2/3/4 seconds?
      BetNumber=6;
      delay(100);
      if(Duration<=2000000&&Duration>=1000000)
      BetNumber=7;
      delay(100);
      if(Duration<=3000000&&Duration>=2000000)
      BetNumber=8;
      delay(100);
      if(Duration<=4000000&&Duration>=3000000)
      BetNumber=9;
      delay(100);
did you mean this by check your use of pulseIn? And what is a debouncing button ?
Read the ref section and look at how pulseIn() work. Clue
timeout (optional): the number of microseconds to wait for the pulse to start; default is one second (unsigned long)
Buttons bounce they do not just go from off to on or on to off they go on off on off ... on your reading looks like the time for one of the bounces.
Hint - Put the code you have away and start over. Write and debug a program which the report the length of time you have held the button down. Then add other bits.
Mark
