In my version (1.6.9), the function is located in \hardware\arduino\avr\cores\arduino\wiring_pulse.c
unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout)
// cache the port and bit of the pin in order to speed up the
// pulse width measuring loop and achieve finer resolution. calling
// digitalRead() instead yields much coarser resolution.
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
uint8_t stateMask = (state ? bit : 0);
// convert the timeout from microseconds to a number of times through
// the initial loop; it takes approximately 16 clock cycles per iteration
unsigned long maxloops = microsecondsToClockCycles(timeout)/16;
unsigned long width = countPulseASM(portInputRegister(port), bit, stateMask, maxloops);
// prevent clockCyclesToMicroseconds to return bogus values if countPulseASM timed out
if (width)
return clockCyclesToMicroseconds(width * 16 + 16);
return 0;
