Here is OP’s code:
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
#include "SR04.h"
int Echo = A4;
int Trig = A5;
//Line Tracking IO define
#define LT_R !digitalRead(10)
#define LT_M !digitalRead(4)
#define LT_L !digitalRead(2)
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
#define carSpeed 150
int rightDistance = 0, leftDistance = 0, middleDistance = 0;
SR04 sr04 = SR04(Echo, Trig);
long a;
void forward() {
analogWrite(ENA, carSpeed);
analogWrite(ENB, carSpeed);
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
Serial.println("go forward!");
void back() {
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
Serial.println("go back!");
void left() {
Serial.println("go left!");
void right() {
Serial.println("go right!");
void stop() {
digitalWrite(ENA, LOW);
digitalWrite(ENB, LOW);
Serial.println("Stop!");
//Ultrasonic distance measurement Sub function
int Distance_test() {
digitalWrite(Trig, LOW);
delayMicroseconds(2);
digitalWrite(Trig, HIGH);
delayMicroseconds(20);
float Fdistance = pulseIn(Echo, HIGH);
Fdistance = Fdistance / 58;
return (int)Fdistance;
pinMode(LT_R, INPUT);
pinMode(LT_M, INPUT);
pinMode(LT_L, INPUT);
myservo.attach(3); // attach servo on pin 3 to servo object
pinMode(Echo, INPUT);
pinMode(Trig, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
stop();
if (LT_M) {
forward();
else if (LT_R) {
right();
while (LT_R);
else if (LT_L) {
left();
while (LT_L);
1. If no line, then stop.
2. If no line, then turn around 180 degrees.
3. Know when the path has ended.
4. If obstacle == true then avoid (stays off line)
5. Return back to the line -- what would nature do?
the call to pulseIn is in the Distance_test() function and that function is never called so I don’t see how that will affect anything.
