PulseIn problem
Hi guys,
First of all thanks for your time. So my problem is I am trying to send a Pulse signal from a Nano to Uno to make sure am sending the right pulse.
When I connect my Uno to the usb and supply from it everything works fine and I get as expected result. As soon as I attach the nano to another supply and leave the uno on usb to use the Serial Monitor I get extra (unwanted) values with my pulse. I also noticed that if I disconnect everything I get a 0.. which is normal.. as soon as I put in a wire on the pin(which on the other end is connected to nothing) I also get the strange values.
Any ideas please?
thanks in advance
Post your code
Post a picture of your setup
Post your errors
I would like not to make assumptions about your problem to find out I am wrong
Razgrizzz:
Sounds like the UNO ground and Nano grounds are not connected. They should be.
Razgrizzz:
It is not 'normal' to get a steady value from a disconnected pin. You should expect random results unless you provide a pull-up (internal or external) or pull-down resistor. With a wire acting as an antenna you can expect even more randomness.
