PulseIn related function not working
Hey everyone,
I have this function which is not working:
void System::Laser_Output_testing()
    duration = pulseIn(LaserStart_IN, HIGH, 1100); //How long is laserStart_pin HIGH (HIGH for longer than 1000 us= laser emission OFF)
    if (duration <= 1000 && duration != 0) //Laser ON
        if (Serial1.available())
            char laser_ABN[32] = "ABN";
            Serial1.write(laser_ABN); // Guide laser ON
            Serial1.write('\r');
            Serial1.write('\n');
    if (duration == 0 || duration > 1000) //Laser OFF
            char laser_ABF[32] = "ABF";
            Serial1.write(laser_ABF); // Guide laser OFF
I want to read how long the input is HIGH so I can send an instruction to a laser, but nothing is happening. I have an osciloscope and the input signal is OK, but the arduino is not responding to the signal. I do not know if it is not running the function or if it is always setting my laser to OFF.
Thank you for your help.
Your code is incomplete.
Can you tell me what is missing?
I am not an expirienced programmer
It's missing a bunch of variable definitions, and a setup and loop function.
Why are you using Serial1.write?
Post the whole code. Posting snippets leaves out important information.
regarding the setup and loop functions, I have this "void System::Laser_Output_testing" running in the loop. the code was too big for me to post here.
main.cpp
#include <Arduino.h>
#include <PID_v1.h>
#include <LiquidCrystal.h>
#include <system.h>
#include <UserInterface.h>
System sys;
UserInterface UI;
//################################### Laser PID #################################
double Setpoint; //target value
double Input;    //Temperature sensor (pyrometer)
double Output;   //ouput value of the PID controller
//PID parameters:
double Kp = 0.1, Ki = 6, Kd = 0;
//Laser PID
PID laserPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
  Serial1.begin(baudRate_1); //Serial 1 = Laser Serial Communication (RS232)
  //Initialize Pyrometer & Laser
  sys.Init_Pyrometer();  //initialize Pyrometer
  sys.Init_LaserStart(); //initialize Laser PIN
  sys.Init_PF();         //initialize Powder Feeder
  //Initialize UI
  UI.BeginConfig(); //Begining Configurations
  //Laser PID Setup
  Input = 0;                         //Tempreature Reading Value ("TR") [ºC]. Defined by Pyrometer input values.
  Setpoint = 0;                      //Temperature Target Value ("TT") [ºC]. Defined in "UI".
  laserPID.SetMode(AUTOMATIC);       //Turn PID ON
  laserPID.SetTunings(Kp, Ki, Kd);   //Set defined Kp, Ki and Kd
  laserPID.SetSampleTime(10);        //Sample time = 10 [ms]
  laserPID.SetOutputLimits(10, 100); //Output limits = Diode Current (10-100% of Max Laser Power)
  //UI Configurations Start (Running Once)
  UI.Config();              //UI request for desired Target Temperature ("TT") and Mass Flow Rate ("MFR").
  Setpoint = UI.TempTarget; //PID Setpoint, user desired value "TT".
  UI.Laser_ON();       //UI intruction to user requesting laser start.
  sys.Laser_InitCOM(); //Establish initial communications to laser. Check "system.cpp".
  UI.PF_Config();   //User Configurations ("TT" and "MFR")
  sys.PF_CompRPM(); //Compute Powder Feeder RPM%
  UI.PF_Purge();    //Powder Feeder Purge
  UI.Ready2Print(); //Processing Ready to Deposit
  if (UI.Ready == true)
    //temperature reading [ºC]
    sys.TempReading();         //Recieve Pyrometer Readings
    Input = sys.TempReading(); //Tempreature Reading Value ("TR") [ºC]. Defined by Pyrometer input values.
    //PID Computation
    laserPID.Compute(); //PID Output Computation
    //Laser Output
    //sys.Laser_Output(Output); //Laser Output Instructions (Serial Communication, RS232)
    sys.Laser_Output_testing();
    //Powder Feeder Control
    sys.PF_CompRPM(); //Compute RPM% that the PF requires to turn at the desired MFR
    sys.PF_Output();  //Output RPM% to Powder Feeder
    //Display Temperatures (Target & Read) and Mass Flow Rate on the LCD
    UI.ProcessingDisplay(Output);
  //SAFE function to test laser communication
  //sys.laser_testing();
system.cpp
#include <system.h>
UserInterface UIsys;
//############################################## SETUP FUNCTIONS ##############################################
//############################################# INITIALIZE PINS #############################################
void System::Init_LaserStart()
    pinMode(LaserStart_IN, INPUT); //Start laser pin (ON/OFF INPUT pin)
void System::Init_Pyrometer()
    pinMode(Pyrometer_IN, INPUT); //pyrometer pin is INPUT
void System::Init_PF()
    pinMode(D1_rpm_OUT, OUTPUT);
    pinMode(D2_rpm_OUT, OUTPUT);
//############################################## LOOP FUNCTIONS ##############################################
//###################################### TEMPERATURE READINGS FUNCTIONS ######################################
double System::TempReading()
    Temp_Reading_V = analogRead(Pyrometer_IN);                  //Temperature read by pyrometer
    Temp_Reading_C = map(Temp_Reading_V, 205, 1023, 600, 2300); //Voltage to [ºC] conversion. Pyrometer Range = 600 to 2300 [ºC]
    return Temp_Reading_C;
//############################################# LASER  FUNCTIONS #############################################
void System::Laser_InitCOM()
    if (InitCOM == false)
            char laser_DMOD[32] = "EMOD";
            Serial1.write(laser_DMOD); // Enable Modulation
            char laser_DEC[32] = "DEC";
            Serial1.write(laser_DEC); // Disable External Control
            char laser_ELE[32] = "DLE";
            Serial1.write(laser_ELE); // Disable Hardware Emission Control
            char laser_EMON[32] = "EMON";
            Serial1.write(laser_EMON); // Emission ON
        InitCOM = true;
void System::Laser_Output(double input)
    duration = pulseIn(LaserStart_IN, HIGH, 1100); //How long is laserStart_pin HIGH (HIGH = laser emission OFF)
            char laser_SDC[32] = "SDC "; // Set Diode Current.
            char laser_PID_input[32];
            itoa(input, laser_PID_input, 10);
            Serial1.write(laser_SDC);
            Serial1.write(laser_PID_input); //PID_value = Diode Current (10-100% of Max Laser Power)
            //Debug Serial Communication:
            // UIsys.debugSDC(laser_SDC, laser_PID_input);
            char laser_SDC0[32] = "SDC 0"; // Set Diode Current to 0% (OFF).
            Serial1.write(laser_SDC0);
            // char laser_SDC000[32] = "00";
            // UIsys.debugSDC(laser_SDC0, laser_SDC000);
//Laser Testing
void System::laser_testing() //Laser comunication testing code (SAFE)
//############################################# POWDER FEEDER  FUNCTIONS #############################################
void System::PF_CompRPM()
    //rpm_perc = UIsys.MFRTarget; //Percentagem de RPM em função do Mass Flow Rate
    rpm_perc = 20; //testing
    rpm_1 = map(rpm_perc, 0, 100, 0, 255);
    rpm_2 = map(rpm_perc, 0, 100, 0, 255);
void System::PF_Output()
    if (UIsys.D1start == true) //Disk 1 ON
        analogWrite(D1_rpm_OUT, rpm_1);
    if (UIsys.D2start == true) //Disk 2 ON
        analogWrite(D2_rpm_OUT, rpm_2);
    if (UIsys.D1start == false) //Disk 1 OFF
        analogWrite(D1_rpm_OUT, 0);
    if (UIsys.D2start == false) //Disk 2 OFF
        analogWrite(D2_rpm_OUT, 0);
void System::PF_PurgeOutput()
system.h
#ifndef _system_
#define _system_
class System
private:
#define baudRate_1 57600
public:
    //Pins:
    const int Pyrometer_IN = A12; //Pyrometer IN
    const int LaserStart_IN = 35; //Communication from RAMPS GCode (START/STOP Processing/extruding)
    const int Start_pin = 50;     //Communication from RAMPS (deposition started = HIGH; depsition STOPED/ENDED == LOW)
    //Powder Feeder Pins:
    const int D1_rpm_OUT = 46; //Output Disk 1 Rotation
    const int D2_rpm_OUT = 44; //Output Disk 2 Rotation
    //##################################  SETUP  ####################################
    void Init_Pyrometer(); //Initialize Pyrometer Readings Pin
    void Init_LaserStart(); //Initialize RAMPS-Laser Communication Pin
    void Init_PF(); //Initialize Powder Feeder Output Pins
    //##################################  LOOP  #####################################
    //##########################  TEMPERATURE READINGS  #############################
    //pyrometer functions (check "system.cpp"):
    double TempReading();
    //temperature variables/constants:
    int Temp_Reading_V = 0;    //temperature read by Pyrometer in [Volts]
    double Temp_Reading_C = 0; //temperature read by Pyrometer in [ºC]
    //################################   LASER   ####################################
    //Initialize Laser Serial Communication
    void Laser_InitCOM();    //Laser Initial Serial Communication (RS232). To run once.
    boolean InitCOM = false; //Initial COM Flag
    //laser functions (check "system.cpp"):
    void Laser_Output(double input); //Laser Output Instructions
    void Laser_Output_testing();
    int duration = 0;
    //################################   POWDER FEEDER   ############################
    int rpm_1;
    int rpm_2;
    int rpm_perc;
    void PF_CompRPM(); //Compute Powder Feeder RPM%
    void PF_Output();  //Output RPM% to Powder Feeder
    void PF_PurgeOutput(); //Used in "UserInterface.cpp"
    int PurgeDuration = 1500;
    ////##################################  TESTING  ################################
    void laser_testing(); //SAFE code to test laser SERIAL COMS
#endif
If you want I can post the UI part of the code, but i think it is not relevant. The loop is running, I can see the temperature reading changing, so it is running well. It is just that first function I posted in the beginning of the thread that is not working
btw, the code is compiling successfully.
@anon73444976 @groundFungus any ideia of what could be wrong?
Did I post too much code now?
Why does there have to be data available on serial1 before you can send a command to laser?
actually it does not. but it worked before. should I be using availableForWrite?
I just want to check if I can send data
I would just comment it out and try it.
still not working
You have the same thing throughout your code. Perhaps one of the precursor commands is important.
I recall that you got some code talking to the laser earlier. Do you have some simpler code to test the commincations?
This is the simplest/safer instruction to test the laser. I do not think the problem is because of the serial communication, what I think the problem is, is that the pulseIn is not reading the pulses correctly or maybe not even reading the pulses.
Or, most likely, my "If" cycle is wrong. I just cannot see the issue.
The serial communication as been tested many (and I mean MANY :sweat_smile:) times before, and it is working fine.
Maybe add some serial prints to that function.
What does your signal look like? The pulseIn() function will return 0 if the signal doesn't go from LOW to HIGH and HIGH to LOW within 1.1 milliseconds and if it DOESN'T return 0 you ignore any pulse less than a millisecond.
