Pump and IR sensor
I want to ask for coding Proximity Capaxitive sensor.When sensor detect object the pump motor will on and when the sensor no detect the motor will be off
Provide a data sheet for the sensor.
Provide a data sheet for the motor driver and motor. What is the power source?
Which Arduino are you using?
What have you tried? Post your attempt and we can try to help. We help people with their code, we seldom write code for people, especially people who will not at least try.
Did you already run the examples coming with the sensor library?
Do you use a motor shield or a single transistor?
