Puredata ardruino drum wireless - Help
I am working in a project with arduinos, xbees and puredata.
after somany days of research I was able to connect wireless a arduino to puredata without firmata… my arduino has 6 analogs sensors and has the code from spikezinelabs running (arduino drums).
in my Puredata patch gets data from any sensor as a single input.
I woud like to separte the data for each sensor and make puredata bang to a software instrument.
any suggestion is very welcome.
arduino code and puredata patch here
puredata patch ( extended version)
http://thewebclass.org/codeout/mypd-serial.pd
arduino code
// * SpikenzieLabs.com *
// * Drum Kit - Kit *
// BY: MARK DEMERS Copywrite 20009
// April. 2009
// VERSION: 1.b
// Balam Soto 2010 add accelerometer support
// Required - Software:
// 1. Serial MIDI converter
// 2. Garage Band, Ableton Live etc …
//The pins are mapped from left to right (0 to 5).
//Starting with Analog pin 0 on the left.
//So, for your project try:
//int PadCutOff[6] = {700,700,700, your pin 3 value , your pin 4 value ,700}; // Minimum Analog value to cause a drum hit
// LEGAL:
// This code is provided as is. No guaranties or warranties are given in any form. It is your responsibilty to
// determine this codes suitability for your application.
// User settable variables
unsigned char PadNote[6] = {52,16,66,63,40,65}; // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {510,500,500,500,360,360}; // Minimum default 600 Analog value to cause a drum hit
//340 average is for Y pin on accelro
// 360 average for X
int MaxPlayTime[6] = {90,90,90,90,90,90}; // Cycles before a 2nd hit is allowed
#define midichannel 0; // MIDI channel from 0 to 15 (+1 in “real world”)
boolean VelocityFlag = true; // Velocity ON (true) or OFF (false)
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0}; // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0}; // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Setup
Serial.begin(57600); // connect to the serial port 115200
// Main Program
for(int pin=0; pin < 6; pin++)
hitavg = analogRead(pin); // read the input pin
if((hitavg > PadCutOff[pin]))
if((activePad[pin] == false))
if(VelocityFlag == true)
// hitavg = 127 / ((1023 - PadCutOff[pin]) / (hitavg - PadCutOff[pin])); // With full range (Too sensitive ?)
hitavg = (hitavg / 8) -1 ; // Upper range
hitavg = 127;
MIDI_TX(144,PadNote[pin],hitavg);
PinPlayTime[pin] = 0;
activePad[pin] = true;
PinPlayTime[pin] = PinPlayTime[pin] + 1;
else if((activePad[pin] == true))
if(PinPlayTime[pin] > MaxPlayTime[pin])
activePad[pin] = false;
MIDI_TX(128,PadNote[pin],127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
status = MESSAGE + midichannel;
Serial.print(status);
Serial.print(PITCH);
Serial.print(VELOCITY);
any help is welcome!
